1st BBF Fox in Russia
+9
gmsmkr
Mustang-junky
butterbean
norg
13 posters
Page 2 of 2 Previous  1, 2
1st BBF Fox in Russia - Page 2 Empty Re: 1st BBF Fox in Russia
Post  butterbean June 30th 2015, 11:17 am
see even a guy from Alabama can help at times LOL!!!!!!!!
butterbean
butterbean
Post  norg June 30th 2015, 12:07 pm
norg wrote:
gmsmkr wrote:Norg..what you have is a 8 pin remote TFI distributor so with that said it only needs 3 wires to run.
Hold the plug with the lock up top
1) +12v in run
2) gnd
3)TFI gnd
4) PIP to TFI
5)no hook up
6)gnd
7)EEC gnd
8)PIP to EEC
Pin layout
1 top left.       So it will go.       1234
                                                     5678
Hook 1 to 12v run power and coil positive
Hook 2 to gnd
Hook 6 to coil gnd
Thank you very much!
I will go in that way.
Still no arc (
hall sensor to be connected carefully
There are 4 wire to hall sensor RED, GRN, GRN, BLK
norg
norg
Post  gmsmkr June 30th 2015, 12:56 pm
You can't run it by the 4cyl comp it has to be a stand alone deal .... hook 1 to switch power and make sure it has power when motor is turning over.
gmsmkr
gmsmkr
Post  gmsmkr June 30th 2015, 1:06 pm
Here is a way to wire a duraspark distributor with a gm hei mod...... if you can't get the 8 pin dis to work is much simpler
1st BBF Fox in Russia - Page 2 Images_zpskmifm1i7
gmsmkr
gmsmkr
Post  norg July 1st 2015, 2:42 pm
gmsmkr wrote:Here is a way to wire a duraspark distributor with a gm hei mod...... if you can't get the 8 pin dis to work is much simpler
You are absolutely right! Thank you cowboy!
Temporary I have bought here local the HEI module from LADA afro
Aaand is RUN cheers It was just 1 second, but cool )
1st BBF Fox in Russia - Page 2 20150701_1858261_zpsphgb0fwn
1st BBF Fox in Russia - Page 2 20150701_1942411_zpsczkyaqij
1st BBF Fox in Russia - Page 2 VAZ%202108%20module1_zpszwiibtp0
norg
norg
Post  gmsmkr July 1st 2015, 5:55 pm
Sure glad you got it going your way Cool
gmsmkr
gmsmkr
Post  Jetman August 12th 2015, 10:46 pm
Nice build, you are doing an awesome job.
Jetman
Jetman
Post  norg August 14th 2015, 3:20 am
Jetman wrote:Nice build, you are doing an awesome job.
Thanks Jetman!
Work is ongoing (just pics):
1st BBF Fox in Russia - Page 2 20150722_134538_zpsq2a3umjg
1st BBF Fox in Russia - Page 2 20150722_141308_zpsj1a8gzou
1st BBF Fox in Russia - Page 2 20150801_142553_zpsmc9kjq6j
1st BBF Fox in Russia - Page 2 20150802_141740_zpsgb26uvvr
1st BBF Fox in Russia - Page 2 20150802_150506_zpskciq50zm
1st BBF Fox in Russia - Page 2 20150802_150539_zpsammoynnb
1st BBF Fox in Russia - Page 2 20150806_185015_zpszlzfj5vj
1st BBF Fox in Russia - Page 2 20150806_190742_zpsnhfw8g36
1st BBF Fox in Russia - Page 2 20150806_190750_zpsuc6qky69
1st BBF Fox in Russia - Page 2 20150806_190913_zpsc8hddnzl
1st BBF Fox in Russia - Page 2 20150808_152641_zpsswkoycds
1st BBF Fox in Russia - Page 2 20150808_152713_zpsrjzhwfyv
1st BBF Fox in Russia - Page 2 20150808_162537_zpstrym4jyg
1st BBF Fox in Russia - Page 2 20150808_194724_zpsk69hfaw4
1st BBF Fox in Russia - Page 2 20150813_193641_zpssbbcnvvv
1st BBF Fox in Russia - Page 2 20150808_183005_zps6nshw7rc
1st BBF Fox in Russia - Page 2 20150809_171050_zpsrys8nqiq
norg
norg
Post  blown86hallet August 20th 2015, 9:57 am
Suspect is that a make shift gas can on top of the hood of the car? Classic!
blown86hallet
blown86hallet
Post  bruno August 20th 2015, 2:03 pm
looking great !!!! time to do a burnout....
http://WWW.CKRME.COM
Post  maverick August 20th 2015, 3:28 pm
blown86hallet wrote: Suspect  is that a make shift gas can on top of the hood of the car?   Classic!
If you rotate that bottle 180* it'll feed under acceleration. Razz
Post  norg August 21st 2015, 1:03 am
Yes sir it's classic Cool
But the holley blue already installed with new tank. The pump made in china and it's leaking.
1st BBF Fox in Russia - Page 2 20150816_115702_zpsvzx7wiyq
1st BBF Fox in Russia - Page 2 20150816_154728_zpscupyxluq
1st BBF Fox in Russia - Page 2 20150816_164822_zpsoingporj
1st BBF Fox in Russia - Page 2 20150816_204536_zpsr5dps0ho
norg
norg
Post  norg August 21st 2015, 1:13 am
bruno wrote:looking great !!!! time to do a burnout....
Tried to do that bruno Very Happy
No rear brake yet. Can't go slow afro
But i hate the exhaust sound on it. The stock GT mufflers and 2" pipe there.
I love how it sound on a truck
norg
norg
Post  butterbean August 21st 2015, 11:12 am
looks like a Russian RED NECK!!!!!!
butterbean
butterbean
Post  norg March 29th 2016, 1:01 am
Hello Gentleman,
So, got one more trouble with the engine.
The intake lifters and cams lobes are destroyed fully.
The exhaust as new.
The damages is different for all 8 pcs, some has a dish, some lightly grinded, some grinded alot 4-5 mm, and one as new.
Scorpions 1.73 rockers half ok, half has damaged bearing.
Did not open the heads yet, but looks like the intake valve catched the pistons on 5 degree ATDC.
Did a lot of measurements at this time for intake valve - and for all the way (+10 -10 degrees both side of the TDC) and no clashing, even have a gap min 4 mm. But it's not true due lobe destroyed.
The valve lift for exhaust - 14,3 mm (0,565") as per specs, for intake valve lift 8 mm (0,314") destroyed.
The springs, pushrods is ok.
Cam xe274h, dove-c, dual springs, stock pistons, rods and crank (truck '94).
What kind of the piston recommended in this case?
Have another cam in the garage - dual energy 275DEH, 275/285, @219/232. 0,515/0,541, 110.
As reason also:
1- the rockers wrong adjustment. But i could be wrong with the exhaust adjustment, but it's ok.
2- the internal spring clashing of coils, but visually there are a gap 2 mm. (measured the exhaust lift).
norg
norg
Post  dfree383 March 29th 2016, 1:29 am
Did you lube the cam properly? Prelude the engine? And run it for 20-30 minutes varying the rpm from 2000-2500 and not let it idle?
Post  norg March 29th 2016, 2:00 am
dfree383 wrote:Did you lube the cam properly? Prelude the engine? And run it for 20-30 minutes varying the rpm from 2000-2500 and not let it idle?
Dave,
I did a mild street build and thought it's not really necessary. Thought it's bolt on, start and drive.
When the engine been started 1 st time it's not accelerate even many hours. Because the car was in garage.
It's was sound noisy, but i never thought it's lifters. I did remove the valve covers, and found some rockers not tight, then i tighted thems (lightly to 0 lash and + 3/4 turn) and going ahead.
Oil pressure was perfect, idling well, acceleration good... then low pressure, noising ... and now disaster )
norg
norg
Post  norg March 29th 2016, 2:39 am
oh and yes, lubricated all parts properly. It's only stay before start up half year, covered by plastic film.
norg
norg
Post  jbozzelle April 6th 2016, 1:53 pm
So, with your new cam installed you started it and let it idle?
If you did that it chewed up the lobes and you have the problem you have now.
Post  norg April 7th 2016, 5:26 am
jbozzelle wrote:So, with your new cam installed you started it and let it idle?
Did again lot's of measurements. Min 3 mm gap between piston and intake valve for range TDC to 10 ATDC.
Found - the the difference of the springs length. Exhaust longer for 0.8 mm. But with full compression there are enough gap.
So - install single springs, new lifters - held 2000 rpm during start up 15 minutes.
Sound ok.
norg
norg
