4.750 4340 crank
hienergy557
61coon
4.750 4340 crank Empty 4.750 4340 crank
Post  IDT-572 January 14th 2015, 1:11 pm
At PRI, I thought Scat was coming out with a new 4.750 4340 crank for the 460.  I called them and they know nothing about it.
Was it Scat or someone else?
4.750 4340 crank Empty Re: 4.750 4340 crank
Post  res0rli9 January 14th 2015, 1:28 pm
Lem knows
Post  61coon January 14th 2015, 2:11 pm
scratch I heard that they were too.
61coon
61coon
Post  61coon January 14th 2015, 2:13 pm
61coon
61coon
Post  Lem Evans January 14th 2015, 3:24 pm
Scat 4.750" = Billet.
Post  IDT-572 January 14th 2015, 3:55 pm
4-460-4750-6700-220 4340 Pro Comp Light Weight and in Super light
Found it on their online catalog.
Post  hienergy557 January 14th 2015, 9:15 pm
Callies also do a 4.750" crank.
http://www.callies.com/crankshafts/magnum/magnum-ford-460/
hienergy557
hienergy557
Post  Lem Evans January 14th 2015, 9:46 pm
hienergy557 wrote:Callies also do a 4.750" crank.
Correct....I've sold a few.
4.750 4340 crank Empty question
Post  747JetMech January 16th 2015, 12:41 am
Is there a point where increasing the stroke will diminish gains due to bad rod ratio?
We have had some forged cranks available from non us suppliers for some time now. Is there any feedback on serviceability on these units? Good luck not so good?
Thx
Tom
747JetMech
747JetMech
Post  the Coug January 16th 2015, 7:07 am
747JetMech wrote:Is there a point where increasing the stroke will diminish gains due to bad rod ratio?
Thx
Tom
Just what do you call Bad Rod Ratio? and whom said it is good or bad?
4.750 4340 crank Empty Hi Coug
Post  747JetMech January 19th 2015, 12:42 am
I remember reading something in Smokey Yunick book quit some time ago... Over 10 years ago..
Tom
747JetMech
747JetMech
Post  the Coug January 19th 2015, 8:23 am
747JetMech wrote:I remember reading something in Smokey Yunick book quit some time ago... Over 10 years ago..
Tom
ok now forget what you read, Rod Ratio, it is what it is just a ratio, .the Rod serves a purpose it connects the Piston to the crank, it takes a lot of stress. but there is no proof good or bad, it is just a word a lot of people throw around, and the Chebby guys like the word evidently. I have ask this question to 100s of chevy and ford guys and no one can explain what a good or bad Ratio is and how they came to the conclusion it was either....
Post  68formalGT January 19th 2015, 10:57 am
I asked and was told not to concern myself with that stuff.
Post  rmcomprandy January 19th 2015, 11:00 am
Tom
That was back in the day when cylinder heads needed as much help as they could get because a higher rod/stroke ratio makes cylinder demand less near the top half of the stroke.
With the air flow capability of heads today, it is almost easy to get enough air flow for the combination.
Post  Lem Evans January 19th 2015, 11:56 am
I agree, the modern cyl. heads make something like a 632" engine more viable than it would have been decades ago.
The small negitives of a 4.750" stroke and a 6.700" rod are greatly offset by the advantage of the extra displacement.
4.750 4340 crank Empty Thanks
Post  747JetMech January 19th 2015, 4:16 pm
Thanks guys for answering my question.
Tom
747JetMech
747JetMech
Post  68formalGT January 19th 2015, 4:40 pm
Lem Evans wrote:I agree, the modern cyl. heads make something like a 632" engine more viable than it would have been decades ago.
Hey Lem, how about in nitrous applications? I've been reading where guys are moving away from the 4.750 to the 4.500 cranks, is this because of the pin placement in relation to the rings?
Post  Lem Evans January 19th 2015, 6:31 pm
That's not the case locally.....then again the tall bbc block is .100" shorter....so maybe they have an issue.
Post  68formalGT January 20th 2015, 2:55 am
That makes sense, thanks Lem.
