Fox K-Member Cross-Over Questions
Fox K-Member Cross-Over Questions Empty Fox K-Member Cross-Over Questions
Post  billandlori January 20th 2015, 10:08 pm
I am finding lots of conflicting info on whether or not the '83 Thunderbird K member will fit in my 80 Fairmont. The Mont was an I6/auto car so the engine mounts are wrong, and the early K is heavier. I read that the Thunderbird has a different rear mounting point, I thought all the Foxes were the same???? The track width is also a bit wider on the T-Bird, I guess with skinnies on the front it won't look bad.
Does anyone have a listing of what fits what??
Thanks,
Bill
Fox K-Member Cross-Over Questions Empty Re: Fox K-Member Cross-Over Questions
Post  Mustang-junky January 20th 2015, 10:33 pm
These guys have a lot of early fox body info on their site.
http://vb.foureyedpride.com/forum.php
I think that the track width difference on the t-bird is because it has longer control arms.
Jess
Mustang-junky
Mustang-junky
Post  billandlori January 20th 2015, 11:26 pm
Mustang-junky wrote:These guys have a lot of early fox body info on their site.
Jess
Thanks Jess, I haven't looked over there in a long time....I'll check them out!
Bill
Post  zbob January 23rd 2015, 8:31 pm
so many combos fit but tie rod lengths, ball joint sizes, and a arms will drive you crazy......bobn
zbob
Post  billandlori January 24th 2015, 12:02 am
zbob wrote: so many combos fit but tie rod lengths, ball joint sizes, and a arms will drive you crazy......bobn
It seems that way!!
I can swap the control arms over, I was just hoping to use the T-Bird K member as its lighter and has the correct engine mounts. I'll have a look at the Hollander numbers and see what matches!!
Bill
