Powerglide trans cross member
I have a 89 miustang with a 429 and a turbo 400 and a Ford motorsport cross member. I am switching to a glide what do you guys recomend to use for the cross member?
cam2- Posts : 14
Re: Powerglide trans cross member
i used the factory double hump cross member and welded a 1/4 inch piece of plate about 4 inches longer and drilled the two holes used the factory rubber power glide trans mount
studly- Posts : 512
used the factory crossmember many times. actually if your motor placement is right you can bolt the glide tranny mount in the factory location. we use mounts for a Chevy II with a glide from 63-64. but most people I see do what is stated above and add the additional plate.
whatbumper- Posts : 3024
Does the engine have motor mounts or use a front and mid plate?
i used motor plates and mid plates, just to get the motor to set where i wanted it to and give additional header clearance, and set the motor a little lower and a little further back in the car than factory.
studly- Posts : 512
I am using motor mounts.Thanks for the input.
cam2- Posts : 14
I'm gonna use a new double hump with the 4" plate on it thanks again for the input.
cam2- Posts : 14
» Powerglide trans
» What Trans Brake DO YOu Use? (Powerglide)
» Differences in C6 transmissions
» Wanted bbc headers for 86 mustang with tube cross member
» Fabbing engine/trans cross members
