Powerglide trans
Powerglide trans
Are strightcut gears good,an also is a 3500 stall torque converter good for a blown motor?
J R- Posts : 82
Re: Powerglide trans
J R wrote:Are strightcut gears good,an also is a 3500 stall torque converter good for a blown motor?
JR starit cut gears are good but no one can tell you what converter to use till you get your engine done and have most of the specks.. Car weight... tire size.. carb... everything you can think of....
the Coug- Posts : 3055
x2 on what the coug says......
Smasher O'Brannan- Posts : 18
What are you gonna' use that blown motor for? Street/Strip?
If it's a street set-up, you would be fine with a helical-cut set but,
if you plan on taking it to the strip, and especially if you plan on using a trans-brake, straight-cuts are the only way to go, IMO.
The helical sets will last for a while but, eventually you will break it.
Hope this helps...
Jeff
Edit-I just saw your thread about the procharger deal...I'd definately take a look at a straight-cut set.
Treeyasoon- Posts : 759
Straight cut for the ProCharger deal!
Nevs- BBF CONTRIBUTOR
the car will most likely weight 3200lb,tire 33x10.5,fuel injection.the Coug wrote:J R wrote:Are strightcut gears good,an also is a 3500 stall torque converter good for a blown motor?
J R- Posts : 82
yes,it will be gear driven.Nevs wrote:Straight cut for the ProCharger deal!
J R- Posts : 82
» What Trans Brake DO YOu Use? (Powerglide)
» Can't get converter on far enough... powerglide trans
» Powerglide trans cross member
» Is a Glide longer or shorter than a C4?
» AJE Fox body Powerglide trans crossmember.
