16 volt battery
FASTLane
16 volt battery
Whats good and what is JUNK. Is a dual volt 12v-16v have any benifits? Do I use the matching charger from the same company? Help. Thanks
FASTLane- Posts : 21
Re: 16 volt battery
Rock is the bomb...............they sell a charger as well, I use one of the old Moroso chargers..............supposedly they are the "cleanest" charging.
No real need for the dual voltage.
Re: 16 volt battery
i have heard great things about the rock set ups .....
but i run the xs power and it is great stuff also
http://www.4xspower.com/old/index.html
Re: 16 volt battery
I run (and sale) Powermaster. I have their 16 volt battery and their intellicharger which is good for 12 volt and 16 volt systems. Once you go 16 volts you will wonder why you ever had a 12 volt system.
Re: 16 volt battery
Not to hijack, but why a 16 volt battery? Easier cranking of high compression engines?
OldRedFord- Posts : 465
Re: 16 volt battery
just makes everything run better.
Re: 16 volt battery
OldRedFord wrote:Not to hijack, but why a 16 volt battery? Easier cranking of high compression engines?
It doe's help in the cranking department. For me i like it because i don't run an alternator. if you have to make a couple passes back to back you don't have to worry about it. It just makes life a little easy in the pits. I have no complaints with the powermaster setup. Bobby Z
665 falcon- BBF CONTRIBUTOR
Re: 16 volt battery
starts quicker
fans/water/fuel pump spin faster --- steady fuel pressure thru the run coller temps
nos noids react quicker and are const. thru the run
the msd's run an un-reg pwr supply ....more const volt thru the run ..more fire
can make several passes before charging
im sure there is more
» 16 volt battery
» Which 16 volt battery do you run?
» Turning Ignition on after turning motor over.
» 16 volt Battery troubles
» Turbo start 16 volt charger SOLD!!!
