16 volt Battery troubles
So Saturday I'm thinking I finally have all the bugs out, ready to race. 1 st round I'm 008 in the tree, dead 3. I'm thinking every body else is in trouble. 2 nd round battery is so dead will not turn over motor. Battery was bought new in November and has been on charger since unless car is running, even between rounds. Put it on charge when I got home, next morning charging light is off. I assume battery charged back up. During the same time the battery died the water pump died also. Did not blow fuse or trip relay. Could the water pump of killed the battery? If so how do I check battery for damage?
sg86coupe- Posts : 184
Re: 16 volt Battery troubles
sg86coupe wrote:So Saturday I'm thinking I finally have all the bugs out, ready to race. 1 st round I'm 008 in the tree, dead 3. I'm thinking every body else is in trouble. 2 nd round battery is so dead will not turn over motor. Battery was bought new in November and has been on charger since unless car is running, even between rounds. Put it on charge when I got home, next morning charging light is off. I assume battery charged back up. During the same time the battery died the water pump died also. Did not blow fuse or trip relay. Could the water pump of killed the battery? If so how do I check battery for damage?
Right kind of lights on the tree
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
FalconEh- Posts : 1448
If you charge between rounds are you making sure to kill the power to the car? If not this may be the water pump issue.
![Suspect](https://2img.net/i/fa/i/smiles/suspect.gif)
The charger is the right one, bought it with battery. And no I did not turn off the kill switch between rounds. So your saying 16 volts is hard on water pumps?
sg86coupe wrote:The charger is the right one, bought it with battery. And no I did not turn off the kill switch between rounds. So your saying 16 volts is hard on water pumps?
16, no.
The 18 plus while charging, yes.
whatbumper- Posts : 3024
whatbumper wrote:sg86coupe wrote:The charger is the right one, bought it with battery. And no I did not turn off the kill switch between rounds. So your saying 16 volts is hard on water pumps?
16, no.
![pale](https://2img.net/i/fa/i/smiles/icon_pale.gif)
» My midplate troubles.
» Which 16 volt battery do you run?
» 16 volt battery
» powermaster 16 volt alt-battery
» low end troubles
» 16 volt battery
» low end troubles
