Jegs 1 wire alternator?
gmsmkr
YellowStangDuane
Anyone use one? I've got some gift certs to use. http://www.jegs.com/webapp/wcs/stores/servlet/m20ProductDisplayView?catalogId=10002&langId=-1&productId=91072&storeId=10001
YellowStangDuane- Posts : 76
Re: Jegs 1 wire alternator?
Never used one but it sounds like a good one as it excites at 800 rpm rather than 1200 like most. I would buy it if it was me
gmsmkr- Posts : 1364
Advance Auto Parts sale a 1 wire alt also I bought one it was like $69 it works great
The alternator looks good but I am not fond of the small pulley, unless you just street drive it, or have a really small crank pulley.
FalconEh- Posts : 1448
I have one from summit like that. Only problem I have is you have to excite it in the lanes. I'll drive to the lanes and later when it's your turn you have to excite it. Mine will go from 12... To 13.7-9 once you do that.
Never had a problem with it and I still charge between rounds for extra insurance. I mostly have it for the round robin deals at the end of the night.
My crank pulley is around 4" I think. Small one on the alt.
70FB- BBF CONTRIBUTOR
One thing to keep in mind is that 800 rpm cut in rating is based engine rpm and the pulley it is supplied with, and probably the standard diameter for crank pulleys. So if you change the diameter of either one to slow it down, that cut in rating will change also. Just a thought to remember when selecting alternators and pulleys.
70FB wrote:I have one from summit like that. Only problem I have is you have to excite it in the lanes. I'll drive to the lanes and later when it's your turn you have to excite it. Mine will go from 12... To 13.7-9 once you do that......
How do you excite a 1 wire alt? Is it just revving it to a certain RPM, or do you use a switch of some kind?
DILLIGASDAVE- Posts : 2262
This is the same alternator I have run for 6 years now. 4 inch pulley on the crank and have had no problems. I idle at about 1300 rpms and it charges great. It keeps the red top charged, and I don't have to charge between rounds.
514Fox87- Posts : 436
DILLIGASDAVE wrote:70FB wrote:I have one from summit like that. Only problem I have is you have to excite it in the lanes. I'll drive to the lanes and later when it's your turn you have to excite it. Mine will go from 12... To 13.7-9 once you do that......
Couldnt tell you Dave. Its a 1 wire going to the battery. This morning I backed it out the shop. The volt gauge read 11.9 or so. Once I tapped the gas above 1300 it jumps straight up to 13.9. Then when I let it idle back to 1000 or so it will stay at the 13.9. Maybe I have the wrong pulley size also?????
» Jegs fuel pump
» ONE WIRE ALTERNATOR INSTALL PROBLEM - HELP!
» one wire 100 amp alternator with bracket & crank pulley
» Summit or Jegs Coupons
» Jegs SuperQuick 32, Chandler, IN - Aug, 14- Anybody
