87 460 bellhousing 95 pedals what clutch master?
87 460 bellhousing 95 pedals what clutch master?  Empty 87 460 bellhousing 95 pedals what clutch master?
Post  Bart Knox February 11th 2015, 2:13 pm
Got 87 460 bellhousing flyweel cluch slave cylinder and line and 95 pedals will the 95 f250 460 master hook up with 87 line or do I need a master from 87 and drill the spuds from 95 pedals wasn't sure if the only difference in the masters were the studs being in the pedals or master
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
87 460 bellhousing 95 pedals what clutch master?  Empty Re: 87 460 bellhousing 95 pedals what clutch master?
Post  jeffgfg February 13th 2015, 12:53 pm
As far as I can tell all the clutch masters are the same for 460's no matter what year. Small blocks are different by year. The slave cylinder is the same for 460's too. So as long as you get a 460 slave and master they should work. Hope this helps.
jeffgfg
Post  BigRigTech February 13th 2015, 2:55 pm
The only difference I've run across is some of the ZF master cylinders had the mounting studs on the MC and some had them on the firewall with holes in the MC. Everything else is the same on a 460 or a 7.3L ZF-5 master/slave and line. I have a re-drilled 460 ZF behind the 95 7.3 Powerstroke in my truck.
BigRigTech
BigRigTech
