true street rules????
Ok guys I am gathering parts for my 1977 f100 I'm going to do a crown Vic front suspension swap and was wondering if any of yall think it would pass tech.... The rules say bolt on stock location suspension is ok. No ladder bars or back half this is the reason I'm staying leaf spring rear but want the new front suspension.
Let me know what yall think.
gmsmkr- Posts : 1364
Re: true street rules????
gmsmkr wrote:Ok guys I am gathering parts for my 1977 f100 I'm going to do a crown Vic front suspension swap and was wondering if any of yall think it would pass tech.... The rules say bolt on stock location suspension is ok. No ladder bars or back half this is the reason I'm staying leaf spring rear but want the new front suspension.
Hey Mike,
I think the CV front suspension is not a direct bolt on, some modification and welding is required...having said that at many tracks probably, but I think the rules are more in alignment with tubular a-arms etc. direct bolt on stuff.
FalconEh- Posts : 1448
Thanks Russ I was thinking the same but I could make it bolt on o well it still getting the CV swap just cause I want the new front suspension once I have everything to get started I will make a build thread.
The Crown Vic swap route might be too much "out of the spirit of the rules" for the rule makers. Especially since it's a "car" front suspension vs a truck suspension. But it wouldn't hurt to ask if you could have a special exemption in this case. You won't know for sure unless you ask.
If the goal is just to get rid of the twin I beams in favor of A-arms what about using a later model A-arm Ford truck chassis under the early truck body? Depending on how it's done a lot of people might not even notice the swap.
DILLIGASDAVE- Posts : 2262
» Project turbo True Street
» 1993 Mustang Notch True Street Car
» True Street at Bowling Green...our first time
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» it cant be true!
» it cant be true!
