Motor PLate Questions
Motor PLate Questions Empty Motor PLate Questions
Post  billandlori March 19th 2015, 9:33 pm
Hey folks,
At what HP level would you need to run a motor plate and mid plate?
Currently I have the Ford Motorsports Fox swap mounts. The front plate would help for header clearance!! I will be getting a set of D&D headers as the Hookers are POS's.
Bill
Motor PLate Questions Empty Re: Motor PLate Questions
Post  Wheelie58 March 20th 2015, 8:40 am
Bill,
It is tough to put a direct horsepower factor on the front/mid plate topic.
I ran an 800+ engine on solid side mounts for many years with no issue.
Things to consider include what accessories need to be mounted on the front of s higher HP mill.
It is not uncommon for 900++ setups to have a vacuum pump, oil pump, fuel pump, alternator, coil and other things hung on the front. A motor plate makes a great platform to mount these components.
When combined with a mid plate and lateral limiter, the entire engine/Trans combo can help apply the stresses involved more evenly to the front of the chassis.
Just some thoughts....
Thanks,
Keith
Wheelie58
Wheelie58
Post  billandlori March 20th 2015, 4:58 pm
Wheelie58 wrote:Bill,
Thanks,
Keith
That's some good info Keith, I appreciate it. I'm right around 500hp, no trans brake, and only will be running an alternator on the front. I like the idea of applying the power more evenly to the chassis.
Thanks again!!
Bill
Post  Larry Williams March 20th 2015, 5:10 pm
I might have a steel mid plate here too
larry
Larry Williams
Larry Williams
Post  72mav March 20th 2015, 7:42 pm
Go for it Bill! How is life treating yas?
Regards.
Al
72mav
72mav
Post  billandlori March 20th 2015, 10:47 pm
72mav wrote:Go for it Bill!  How is life treating yas?
Regards.
Al
Things are going good here, how's about you?
Bill
