Mustang Instant Center
Mustang Instant Center Empty Mustang Instant Center
Post  nitro717 November 21st 2009, 7:33 am
Adjusting the rear ride height alters the rear control arm geometry thus moving the Instant Center..So if you put a larger tire (diameter) on and keep the same ride height you have moved Instant Center.? So the larger tire will give you a bigger footprint, should hook better, moving the instant center which way is causing it to??
nitro717
nitro717
Mustang Instant Center Empty Re: Mustang Instant Center
Post  bosshoss November 21st 2009, 2:03 pm
Without doing the map thing it is difficult to guess exactly but assuming you indeed do not change the height of the body and just raise the rearend in the car then it follows that the intersect point would have to move down. The distance from the rear axle probably would not change very much if at all.
dkp
bosshoss
bosshoss
Post  feetfirst November 22nd 2009, 10:44 am
How much of a height difference in tire size? It will only change the AS values, not the IC length.
feetfirst
feetfirst
Post  nitro717 November 22nd 2009, 5:52 pm
going from a 28 to a 29.5
nitro717
nitro717
