Cleaning Head Bolt Threads
For next to nothing you can make your own thread chaser. Get an extra head bolt and use a Dremel cutoff disk and make the vertical slit around the bolt at each 45 degree points. Use some brake clean to loosen the crud and after running your bolt in and out blow out with your air gun.
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Cleaning Head Bolt Threads
you know what also cleans them nicely a Bottom hole tap. That's what I clean threads with seem to be what they are made for....
the Coug- Posts : 3055
the Coug wrote:you know what also cleans them nicely a Bottom hole tap. That's what I clean threads with seem to be what they are made for....
^ This is what I use.
D. Sea- Posts : 2768
» coolant leak between head and block at head bolt location.
» What do you use for cleaning the block and head gasket surfaces ?
» Stripped Head bolt
» Head bolt?????
» 18 head bolt torque plate
» Head bolt?????
