Hitting brake caliper
Has anyone ran into the problem when using stock front brakes with a 2.25 bs 15x3.5 front wheel on a foxbody. I pretty sure I'm going to have to use a spacer or go to aftermarket brakes
larry552- Posts : 335
Re: Hitting brake caliper
Wrong off set is what causes this
gmsmkr- Posts : 1364
Ive got 1/4" spacers on mine w 4" wheels.
dirt_worker- Posts : 535
This is the back space I seen most guys running on yellowbullet bullet with mustangs. Just trying to see has anyone else ran into this problem. I will make it work either way
Backspace and offset are different things
this should help understand what I mean
You could have the same backspace as everybody else but offset is what makes it work with your set up
Some brake setups are meant for a 16"+ (17,18,20) wheel also, if it is hitting on the lip, it might be meant for a larger diameter rim.
FalconEh- Posts : 1448
It just the caliper hitting the back side of the wheel. Really the pad height needs to be thicker on the wheel. For now I think a spacer will work
Larry I had to put a 1/4" spacer on the front of my ranger when I did the strut frontend swap just remember you need longer studs when adding the spacer
https://s1295.photobucket.com/user/hotrod4923/media/Mobile%20Uploads/1429022348_zps48a242b7.jpg.html?sort=3&o=0
» Aerospace Brake Caliper Bleed ?
» 9 inch ford disc brake caliper brackets
» Rod bolts hitting pick up tube
» Roller Rocker not hitting valve squarely
» Trans Brake vs Foot Brake
