Cam question
Cam question
Cam spec at .050 280/300 adv du 313/340 .750 lift. 112 lobe sep .would this cam work in a twin turbo aplication...9-1 compression race fuel?thanks.
Will Brewer- Posts : 14
Re: Cam question
What type of turbos are you using
gmsmkr- Posts : 1364
Re: Cam question
way too big. Lift is fine. duration is crazy.
whatbumper- Posts : 3024
Re: Cam question
Turbo engines run faster (at the track) when you open the exhaust valve sooner. With short intake duration, the engine responds with speed at the track. By opening the exhaust valve sooner with either a tighter lobe-separation angle or long exhaust duration, the engine generally responds better. You will lose scavenge if you open the exhaust valve too late.
Re: Cam question
Yea, I kind of thought that may be too big .i I also have another cam .640 lift duration at .050. Is 270/276 adv dur 310/314 108 lobe sep.would that work? The turbos are 77mm
Re: Cam question
With what you have that would be a starting cam but if you had the funds I would give a call to your choice of cam guys and let them cut a cam to your app it would be ALOT better than a OTS cam
Re: Cam question
It is better on the duration and lobe separation sides but now the lift is probably too low for your heads depending on how they are finished out.
Your best bet is to get a custom cam. It is the heart of the motor so you can't just get by. The cam is probably more important to a turbo motor than the heads.
» C6 Question
» question for somebody who knows.
» jr question
» Custom oil pans???
» C6 Question
» jr question
