Top loader
+6
DanH
tabcobra
butterbean
10 posters
Top loader Empty Top loader
Post  butterbean April 28th 2015, 8:54 pm
I met a guy today that has a 4 speed top loader tranny out of a 1965 Ford sports car (looks kinda like a cobra) but its not and its not a Mustang, it had a 271 HP 289 engine in it too, anyway he wants to sell the tranny and shifter and don't know what its worth, anyone know what kinda car it came out of? and what its worth???
butterbean
butterbean
Top loader Empty Re: Top loader
Post  maverick April 28th 2015, 9:04 pm
Was it a Sunbeam Tiger? Wasn't actually a Ford...just Ford powered.
Post  butterbean April 28th 2015, 10:34 pm
no it was a ford, this car was a 1965 model with a 289/4 speed
butterbean
butterbean
Post  tabcobra April 28th 2015, 11:30 pm
Should have taken a picture of that car...one thing's for sure though, you don't want to put that trans behind a big block.
tabcobra
Post  bbf-falcon April 29th 2015, 10:57 am
tabcobra wrote:Should have taken a picture of that car...one thing's for sure though, you don't want to put that trans behind a big block.
True that. If memory serves me right,reverse is to right and down on Top loader,and left and up on the T10's.
Post  butterbean April 29th 2015, 11:01 am
sorry guy's for the confusion but the guy told me it was a ford but its not, its a 1965 Griffin with the Ford drive train, anyway the top loader came out of it and it has the Griffin shifter and linkage in tact
butterbean
butterbean
Post  maverick April 29th 2015, 11:13 am
As I recall, Ford used different toploaders for small blocks and bigblocks. The smallblock unit is strictly that...a smallblock trans.
Post  Doug Rahn April 29th 2015, 11:55 am
maverick wrote:As I recall, Ford used different toploaders for small blocks and bigblocks.  The smallblock unit is strictly that...a smallblock trans.
True, small blocks had 28 spline output shaft and the big blocks had 31 splines including the NASCAR trans. Wink Oh, I forgot to add that some of the small blocks were also available with 31 splines. I think even the 1964's Mustangs had a 25 spline
Post  DanH April 30th 2015, 3:08 am
big blocks = FE's in the 60's. the bb's also had 1 1/16" 10 spline inputs and 28 spline outputs.
DanH
Post  butterbean April 30th 2015, 9:18 am
Thanks, I will go by there and count the splines when I get a chance, so is it worth anything???
butterbean
butterbean
Post  460pulling April 30th 2015, 10:32 am
Here is factual info on this subject. He lists the trans for the griffin/tvr. One of the best sites/ guys on the subject. Although he can be a pain to talk to.
http://www.davidkeetoploaders.com/idchart1.htm
HEH-CF 1965 TVR, Griffit 289 wide 25-1/2" trans
460pulling
Post  whatbumper April 30th 2015, 10:52 am
460pulling wrote:Here is factual info on this subject. He lists the trans for the griffin/tvr. One of the best sites/ guys on the subject. Although he can be a pain to talk to.
He is very good at working those transmissions over as well. Plus he has a badass Falcon race car.
Post  Doug Rahn April 30th 2015, 10:55 am
butterbean wrote:Thanks, I will go by there and count the splines when I get a chance, so is it worth anything???
Probably only to someone building a Sunbeam Tiger. Considering the year it was used in that car it will have the narrow 4 bolt main case.
Waaaaaaay back in the day Laughing Laughing I used a 31 spline behind my Bud Moore 351C with 600+ hp and never had any problems, it was a tough transmission for the time.
Post  Doug Rahn April 30th 2015, 11:09 am
Cool, David Kee has some photos of what I am talking about with the narrow bolt pattern main case. Later cases had both. Top loader 4and8holecases
I've only seen that on early 260/289's, finding a bell housing with that pattern would be tough.
Post  460pulling April 30th 2015, 11:28 am
I found him by looking for a 1-3/8 x 10 np435 input trans. He redid a 428 cobrajet powered torino 4 speed toploader for my neighbor. It looked like it rolled off the assembly line.
460pulling
Post  the Coug April 30th 2015, 11:40 am
Doug Rahn wrote:Cool, David Kee has some photos of what I am talking about with the narrow bolt pattern main case. Later cases had both. Top loader 4and8holecases
that small pattern came in 63-65 cars laters have the bigger bolt patterns
Top loader Empty Toploader
Post  blown473 May 24th 2015, 10:20 pm
There's no factory bell for the early narrow bolt toploader to 429-460, but you could drill and tap a Lakewood SFI bell for it as the center hole is the same and the surface is flat where the holes need to be drilled. Quick Time uses a different mount and I don't think there's enough material there to drill for the early trans. So far my Toploader has held up well behind my blown 521, but I'm not clutch dropping on slicks either.
blown473
blown473
