What trans to go with my street 545?Top loader or c4?
I am building a pump gas 545 that will hopefully make north of 600 rwhp. It will be going in my 87 notch mustang, and I am a little lost on that trans to go with. Car will see alot of street miles around town with a few car meets that require driving from city to city. My main goal is a street car that can go to the track run a 10 second quarter mile and be reliable.
This brings me to my tranny option. When I first embarked on the big block idea I was sold on a c4. Lighter than the c6 and heard its very strong. Then I got a little worried I would be bored of a auto as I have always owened a manual. With that being said I have been doing a little research on the top loader. Read its, strong and parts are of plenty and I get to keep my car a stick. A tremec would be awesome, but the cost is just to much this late in the build. Figure 3 gears isnt enough and 5 is to expensive, so I will meet in the middle at 4 haha.
My main question about the top loader is if there is a big enough aftermarket for them? Is there people that make these things able to handle a big block over 550 rwhp? What top loader to try and get as there is a close and a far ratio? I dont plan on going to the track more than a few times a year and dont plan on launching at 7k ever. . If I reach that point a auto will be installed. I have read a little about the swap and aware of the problems I am encounter. Also is it cheaper than the tremec. I currently have a tremec 3550. Would it be cheaper to build it to handle my combo? Also the question of header clearance. I plan to use the d&d swap kit with the 2 1/8 headers. I know the c4 will fit, but what about the top loader?
Sorry for the long thread, just trying to get some answers.
JOEY
JOEY
jmh87chpnotch- Posts : 4
res0rli9- BBF CONTRIBUTOR
Re: What trans to go with my street 545?Top loader or c4?
Believe me I have pondered the idea. But 3 gears just seems like it wont be enough for the highway cruises I plan to do. I have been looking at a magnum t56.
jmh87chpnotch wrote:Believe me I have pondered the idea. But 3 gears just seems like it wont be enough for the highway cruises I plan to do. I have been looking at a magnum t56.
OK then put a Built AOD in it
i dont have a 545 but i have used spray in my 472 and it held just fine with a overdrive. i have over 120 passes at the track and even more playing on the street. i used spray only 3 times at the track because they throw me off i do. last year i even locked the converter on spray and every thing held but was worry. i use a 700r4 art carr and converter
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
I looked into a AOD but they are pricey to be able to handle a big block. I also heard its better to go with a aode as you can lock the converter when cruising. I can get a full magnum t56 swap with bell and what not for 4k. Not bad of a deal.
the 700r4 i have will lock up the coverter in 2,3 and 4th the coan adapter was $400 trans and converter $2300. but the 4l80e is the best overdrive they will hold 1200hp.
2009 2010
2009 2010
» Top loader
» CLUTCH FOR TOP LOADER 4 SPEED
» Graden Tractor front end loader
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» need a different trans
