Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads?
Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads? Empty Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads?
Post  jbozzelle November 22nd 2009, 1:44 pm
Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads? Or will I run into any interference issues...
Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads? Empty Re: Do the Blue Thunder 'pentroof' valve covers clear the SCJ and P51 heads?
Post  res0rli9 November 22nd 2009, 2:18 pm
No thay wont work.. You need to send them to me Very Happy J/K
Post  jbozzelle November 22nd 2009, 2:21 pm
res0rli9 wrote:No thay wont work.. You need to send them to me Very Happy J/K
No problem. I'll swap you the covers for your truck... Very Happy
Post  63boxtop November 22nd 2009, 3:03 pm
that would be a good trade cheers
63boxtop
Post  res0rli9 November 22nd 2009, 3:28 pm
63boxtop wrote:that would be a good trade cheers
it be a better trade if he sent them to me fist so I could put them on befor I send the truck to him Shocked Very Happy Very Happy
Post  c.evans November 22nd 2009, 4:39 pm
They probally will work, with some pretty heavy grinding on the inside. The area of conflict is the valve cover bolt boss at the lower left corner and the # 4 (or #5) valve spring and retainer.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  jbozzelle November 22nd 2009, 8:03 pm
I'll just get some FRPPs from lem. They're cheaper and I won't end up grinding on a new set of $200+ valve covers...
Post  rmcomprandy November 23rd 2009, 1:33 am
When a customer insists upon using those valve covers on a Cobra kit car or whatever, as long as it has a street/strip hydraulic or solid lifter camshaft, I use "Beehive" valve springs and retainers on the exhaust side. Those will clear.
