Maximum Dish Size in Piston?
Maximum Dish Size in Piston? Empty Maximum Dish Size in Piston?
Post  Tore May 11th 2015, 11:54 am
I was wondering what is max dish you can put in a piston to lower the Comp ratio?
Thanks Tore
Tore
Tore
Maximum Dish Size in Piston? Empty Re: Maximum Dish Size in Piston?
Post  kim May 11th 2015, 6:26 pm
If the pin is exposed its a little deep.  Really depends on piston design.  If you short rod an engine and drop pin height rediculously  low you can have a custom piston with one hell of a dish.
kim
Post  rmcomprandy May 11th 2015, 7:02 pm
Tore wrote:I was wondering what is max dish you can put in a piston to lower the Comp ratio?
Thanks Tore
That depends upon the height of the top of the connecting rod small end when installed.
Post  gt350hr May 12th 2015, 1:52 pm
minus 38-40 cc's is about all that is practical. beyond that you leave the piston below the deck for more volume. At that point "quench " is not important anymore.
gt350hr
Post  Tore May 12th 2015, 7:48 pm
Tks guys Tore
Tore
Tore
