cam walk
cam walk Empty cam walk
Post  chuck May 11th 2015, 10:10 pm
When try to set the timing on a lock out distributed, as I rev the engine the timing climbs with rpm. Does this sound like cam walk, if so what needs to be done to fix it?
chuck
cam walk Empty Re: cam walk
Post  rmcomprandy May 11th 2015, 11:15 pm
If the cam is walking in a Big Block Ford something is absolutely wrong as cam thrust should be no more than .012" end play.
Post  chuck May 11th 2015, 11:32 pm
[quote="rmcomprandy"]If the cam is walking in a Big Block Ford something is absolutely wrong as cam thrust should be no more than .012" end play.[/quote
Thanks Randy, anything else that could cause the timing to move on a lock out distributor when you bring the rpm's up?
chuck
Post  dfree383 May 11th 2015, 11:53 pm
Is it locked out properly?
What box are you running? Is it programmed right?
Is your timing light working properly?
Post  FalconEh May 12th 2015, 1:02 pm
Check the wires to the distributor, they should be twisted, isolated and not in contact with metal parts.
Post  chuck May 12th 2015, 9:28 pm
I got few test I'm going to try. Spoke with a tech at msd.
chuck
