Total timing with 10.5:1 Compression
+13
TommyK
78ranger
kim
DanE
BigRigTech
gmsmkr
jgkurz
17 posters
Page 5 of 5 Previous  1, 2, 3, 4, 5
Total timing with 10.5:1 Compression - Page 5 Empty Re: Total timing with 10.5:1 Compression
Post  jgkurz June 24th 2015, 12:58 pm
Dyno Results below. The dyno operator recommended 22% for drivetrain loss so that puts me at 353hp and 417ftlb. AFR's look nearly perfect after a ton of work on the Edelbrock 1411 carb. Added some 100 octane for safety. Total timing is at 32deg. Edelbrock is calibrated to #23 position with high flow needles and pressure is set at 5.5psi.  HP and torque are about what I expected. It's a nice cruiser.
Total timing with 10.5:1 Compression - Page 5 429%20Dyno%20Runs_zpshgq1u2ay
Total timing with 10.5:1 Compression - Page 5 AFR_zpsaho6bsrf
jgkurz
Post  78ranger June 24th 2015, 4:12 pm
Glad to see you got it worked out. Are you able to run it on pump super?
78ranger
Post  jgkurz June 24th 2015, 8:07 pm
78ranger wrote:Glad to see you got it worked out. Are you able to run it on pump super?
It runs great but still spark knocks on 92. I've thrown in the towel on this engine. The next engine will not have this issue. Regardless it's a nice cruiser and super reliable.
jgkurz
