C6 pan gasket.
C6 pan gasket. Empty C6 pan gasket.
Post  BigBlockRanger June 4th 2015, 10:05 am
What does everyone prefer?
Mopar make a GREAT reusable one for 727's and 904's that is plastic with rubber molded into it.  They are excellent and I have never had one leak a drop.
Anyone make a similar gasket for a C6?
I just rebuilt my C6 with the help of a friend the owns a transmission shop. It was a pretty interesting experience. Everything looked pretty good inside except for the high gear clutches.  They were getting pretty toasty.
C6 pan gasket. 11406824_10153386999089485_5650816841196963571_n
C6 pan gasket. Empty Re: C6 pan gasket.
Post  Gregaust June 5th 2015, 6:00 am
If you are using a steel pan , I'd use a cork type , it is forgiving if the pan isn't perfectly flat .
For an aluminium pan, I like the Farpak type gasket or cork.
I've not used the type you mentioned but I did hear from a guy I help used one said was pretty good .
Gregaust
Post  mustang68mustangs1 June 7th 2015, 7:25 pm
Moroso make a nice rubber with steel inside gasket. About 30 bucks though!
Bob
mustang68mustangs1
Post  BigBlockRanger June 9th 2015, 8:46 am
I did find that Moroso one, but they say its for cast aluminum pans only. IDK why though.
Post  mustang68mustangs1 June 9th 2015, 9:58 am
I have the moroso gasket . Its a nice one but my pan still leaks . I have a steel pan. No matter what i do i cant seal this pan. I guess sometime im gonna spring for the Moroso alum pan.
Bob
mustang68mustangs1
Post  BigRigTech June 9th 2015, 1:40 pm
I ordered the Moroso pan gasket for mine yesterday. I have the TCI aluminum pan and the friggin cork gasket is always seeping. I had a servo gasket leak so I had to take the shield off to fix that so now is the time to try the rubber pan gasket I guess.
BigRigTech
BigRigTech
Post  BigBlockRanger June 9th 2015, 2:02 pm
I also found these:  Lube Locker gaskets.  I have read good things about their diff gaskets.
http://www.4wheelparts.com/Drivetrain-Differentials/Ford-C-6-Transmission-Pan-Gasket-by-LubeLocker.aspx?t_c=12&t_s=381&t_pt=3657&t_pn=LULLLT-F0C6
C6 pan gasket. 80-photo_4_4_e7c6502b41840de49dfe02a0b1eb9e1397eaae26
Post  mustang68mustangs1 June 9th 2015, 8:28 pm
That lube locker gasket looks good i might have to try one and save the moroso for when i get an alum pan.
Bob
mustang68mustangs1
