Who makes headers for C heads?
+6
wayney
rocketpony
10 posters
Who makes headers for c460 heads? Only I know is d&d
rocketpony- Posts : 120
Re: Who makes headers for C heads?
The Fab Shop did mine. http://www.fabshopheaders.com/categories/dragster-headers-1.html
schmitty- Posts : 4538
Fab shop did mine.
Curt- Posts : 2791
Called fab shop, they no longer do em. They said they will sell me flange n kit to build my own
what chassis do you need them for?
wayney- Posts : 187
Fox body with motor plates
ok, my recommendation is to contact a local chassis shop and have a custom set built. with those heads in a fox with factory strut towers / suspension that is the only way they will fit good. if you buy a pre built header than more than likely a couple tubes will need moved due to motor location, K member brand , etc.
wayne
wayne
wayney- Posts : 187
Where are you located.
TravisRice- BBF CONTRIBUTOR
I'm in newfoundland Canada, so bringing to a shop to have a set fabed up isn't a option
Gonna have to build mine.......
going to have to build them yourself.rocketpony wrote:I'm in newfoundland Canada, so bringing to a shop to have a set fabed up isn't a option
Contact Charlie Evans,he should know. maybe Keith Fulp will make some. Keithfulpmotorsports
Your best bet is to get a BB Chevy header kit, with the appropriate sized header primary pipes. Then get a set of C-460 flanges from Jon Thee or the Fab Shop. Then build your own headers, knowing that you'll discard the BBC flanges.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Is Jon still around? Haven't heard anything from him lately.
crittersf1- Posts : 521
https://www.429-460.com/t4850-jon-thee-header-flanges?highlight=thee
http://www.ebay.com/itm/Kooks-7025-C460S-2-3-8in-SS-BBF-C460-Flange-Bank-fit-Ford-All-Models-/131493812802?hash=item1e9da45a42&vxp=mtr
» 588ci P51 N/A Deal Makes 1042hp with 2 inch Tri Y Headers..some more info on combo.
» What headers for c-460 heads in a fox body mustang?
» FPA headers with Edelbrock heads
» F-150 headers with D0VE heads
» 2 1/4 headers for foxbody A460 heads
