F-150 headers with D0VE heads
F-150 headers with D0VE heads Empty F-150 headers with D0VE heads
Post  95lightiningguy November 24th 2014, 12:49 am
Ok, since the engine didnt sell I went ahead and installed it into the truck, the problem is when I went to install the headers they hit the cross member before they lineup with the exhaust. My question is, is there a specific header for this as I bought a set for 83 F-350 because I was under the impression that they used the D3VE heads at that time, and they have the same exhaust flange as a D0VE, am I mistaken in this? The headers bolted right up to the motor on the stand, everything lined up perfectly, they just dont fit in the truck. Its a 95 F-150 and will be street driven with all accessories and a/c.
95lightiningguy
95lightiningguy
F-150 headers with D0VE heads Empty Re: F-150 headers with D0VE heads
Post  fastbarry November 24th 2014, 12:53 am
what are you using for motor mounts and towers?
fastbarry
fastbarry
Post  95lightiningguy November 24th 2014, 1:46 am
The Ford towers and mounts from an F350, believe it was a 94 I pulled them off of at the local pic-n-pull.
95lightiningguy
95lightiningguy
Post  HorsinAround November 24th 2014, 12:24 pm
What tranny cross member are you using? The one from the mid 90's is straight (at least the one that was on my inline 6/5spd manual) and the earlier ones have a drop in them. I can get you a picture tonight.
http://www.frontpagefab.com
Post  95lightiningguy November 24th 2014, 11:39 pm
HorsinAround wrote:What tranny cross member are you using? The one from the mid 90's is straight (at least the one that was on my inline 6/5spd manual) and the earlier ones have a drop in them. I can get you a picture tonight.
I will be modifying the straight trans cross member that came out of the truck.
95lightiningguy
95lightiningguy
Post  95lightiningguy November 24th 2014, 11:44 pm
Ok, has anyone done this swap and used headers with dove heads? I have searched and read, but I cant find anything.
95lightiningguy
95lightiningguy
Post  lghting94 November 25th 2014, 9:59 am
Do you have any pictures of the headers, mounts we could look at and maybe get you an answer?
lghting94
lghting94
Post  HorsinAround November 25th 2014, 12:51 pm
95lightiningguy wrote:Ok, has anyone done this swap and used headers with dove heads? I have searched and read, but I cant find anything.
I put Hooker Super comp inside the frame headers on a 90 F250 with a 460 with Doves and they worked fine, but I was using the C6 cross member that had the drop in it.
I also have a 460 in a 95 F150 but am using Maddog out side the frame headers. You can check out that build thread here.
https://www.429-460.com/t16148-1995-f150-pro-street-project-thread
Post  95lightiningguy November 25th 2014, 10:50 pm
I am pretty sure I have the wrong ones, have a guy local who has an 82 F-250 with a set of hedman headers and they dont look anything like what I have, so, they are the wrong headers. Thanks for your help and responses guys.
95lightiningguy
95lightiningguy
