99 - 04 mustang
99 - 04 mustang Empty 99 - 04 mustang
Post  garys gt June 17th 2015, 9:43 pm
Has anyone done a 460 in a 99 - 04 mustang with out changing the k member ? ....not sure if I posted in the correct area.
garys gt
99 - 04 mustang Empty Re: 99 - 04 mustang
Post  gmsmkr June 18th 2015, 11:49 am
Use all fox swap parts it's a bolt in deal... just real tight space. with stock K I would use D&D mid length also if you are running hydro boost run stock style valve covers and space the k down 3/4 inch.
The after market k are cheap now days....
If it was a gt car I would recommend changing the k the 4.6 sets the motor 1" high and 1" forward swap to a fox k and you got it whooped.
gmsmkr
gmsmkr
Post  garys gt June 18th 2015, 12:01 pm
So the v6 3.8 99 - 04 car is like the 5.0 fox k-member. Stock k-member will work with 460 but will be tight ?  When you say space or drop the k-member would that be just unbolt it and add spacer or washers to lower it ?
garys gt
Post  gmsmkr June 18th 2015, 12:12 pm
I'm not sure about the v6 k.... but I think they just set the motor up 3/4inch high
Yes unbolt the k and add shims
gmsmkr
gmsmkr
Post  gmsmkr June 18th 2015, 12:14 pm
My car was a v6 but I swapped it out right off for tubular
gmsmkr
gmsmkr
Post  garys gt June 18th 2015, 12:57 pm
There are several different brands of k-member.  Aje and UPR and q a1 and others. Is any of them better to use than the other for bbf....I am going to use a motor plate I got from keith. Is it necessary to go with the other pieces as in upper and lower control arms and bump steer and coil over springs and such....other than weight savings. Over the stock control arms and such...i put a complete setup on my sons car a while back that he put a 351w in...it is noisier than the stock stuff.it was all UPR stuff. His caster and camber plates didn't have enough adjustment to help much. What is most using for bbf ?
garys gt
Post  gmsmkr June 18th 2015, 3:00 pm
Take your pick on the k member .... do the research and pick the one that best suits your needs and as for C/C plates I run the 4 bolt type and mod as needed.
They offer k members with out perches also
gmsmkr
gmsmkr
Post  garys gt June 18th 2015, 3:35 pm
Did you go with the aftermarket control arms and coil over springs
garys gt
Post  garys gt June 18th 2015, 3:43 pm
I also seen the k-member with the 2 inch drop.  would that help any  or is that to much like you were talking about on the dropping in down 3/4 of a inch.
garys gt
Post  gmsmkr June 18th 2015, 3:54 pm
I'm full tubular front and rear with coil overs at all 4 corners
If your running a plate and no mounts I would opt for the 2" drop k so you have plenty of room to set the motor where you like also you ( might )need a steering shaft extender.
gmsmkr
gmsmkr
