Rearend gears with 1.76 glide 29.5 / 10.5 tire ??
New combo , switching from 3 speed to a glide 1/8 1/4 , n/a 3000 fox
Re: Rearend gears with 1.76 glide 29.5 / 10.5 tire ??
1.76 glide 10.5 .29.5 tire rear gear suggestions , thanks
how much HP??? N/A or spray??? how high do you turn it???
butterbean- Posts : 676
New combo, aheaded514 14.5 comp , 850lift Bullitt cam solid roller n/a haven't finished the engine assembly yet , I have 4.11 gears in the car now , glide 1.76 , not looking to turn 7200 / 7500 tops anyone haven't dynoed engine yet , should make between 850 - 950 hp ? My original combo was a dove headed 13.1 514 , c4 4.56 gears
If the car is 3k or less I would try the 4.11 gear but if the car is already set up with the 4.56 gear run it first and see where it falls.
gmsmkr- Posts : 1364
My car was leaving hard with the 4.56 , c/4 , 1.28 60 ft times , I'm sure the glide with 4.11 's will calm the launch down , hopefully not too much , the ahead combo should make up the difference !
I would run the 411 gears but it may like a 430 as well but it won't be happy with the 456 gears because it will be turning to many rpm's in the 1/4, if it makes that much HP.
Thanks for the replies, I'll see how the 4.11's work out 1st , if they don't work out 4.30's maybe my next choice. Thanks again !
» 8.8 rearend 4.10 gears
» 557bbf glide big tire turn key 8900
» Can tire shake knock a 'glide band loose? ***problem solved****
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» tire size back half frame kits tire width on 70 mustang
