Milling P51 Heads
Milling P51 Heads Empty Milling P51 Heads
Post  quikmule84 July 7th 2015, 12:56 pm
Have a 501 BBF with @ 12:5 compression, race only. Would like to increase compression while motor is out. How much do the heads (P51's) need to be cut to pick up 1 point of compression? Would like to end up between 13.5 to 14.5 comp. Pistons in the hole .005. How far can I go before getting into intake alignment issues?
quikmule84
Milling P51 Heads Empty Re: Milling P51 Heads
Post  dfree383 July 7th 2015, 2:35 pm
At .030 it's going start affecting bolt holes on the intake.
I've ha CJ heads decked to 62cc and slotted intake holes and made intakes work with out milling them.
Post  supervel45 July 7th 2015, 5:31 pm
http://wallaceracing.com/cr_test2.php If he has 72 cc's now and goes to 62 cc's he should be in the low 14/1 range with flattops and 0ne 3cc valve relief.
Post  IDT-572 July 8th 2015, 10:33 pm
What ever you mill the deck just cut the intake face half that and the intake will bolt right up.
Post  quikmule84 July 9th 2015, 1:13 am
Ok. Thanks for all the advice. Also, generally speaking, how far can I mill the heads before having to change pushrod lengths.
quikmule84
Post  IDT-572 July 9th 2015, 9:00 am
quikmule84 wrote:Ok. Thanks for all the advice. Also, generally speaking, how far can I mill the heads before having to change pushrod lengths.
.050 makes a difference in your rocker geometry. but you need to see how it looks now before you start.
Post  wayney July 9th 2015, 6:27 pm
is there a specific amount to mill per CC of chamber reduction? ex. .005 per CC?
wayney
Post  supervel45 July 9th 2015, 7:16 pm
http://www.wallaceracing.com/millcalc.php You could run the numbers through here.
Post  IDT-572 July 9th 2015, 7:30 pm
If I remember right it's about .0055 to .006 per 1 cc
Post  supervel45 July 9th 2015, 7:31 pm
For what it's worth that calculator comes up with .2 points of compression increase with a 4.15 stroke crank and .005 removed, with a 12.5C/R as a start. It mentions Pontiac so be aware of that.
