Need JW Wheel immediately - Help locate
I need part number LPT-93001-x Immediately. I have had it on order with Summit for over a month. JW was supposed to manufacture and ship 2 weeks ago. Manufacturing still has not started. Trans is here. Engine will be here Tuesday night.
Re: Need JW Wheel immediately - Help locate
call phillip Oakley
he uses tci
he uses tci
Larry Williams- Posts : 884
He answer the phone on Saturday? IF he's not racing somewhere?
Monday I can price you one from another source that we have but I hate to tell you unless it is magically on someones shelf you aren't getting it from JW any time soon.
whatbumper- Posts : 3024
Thanks. I'm hoping someone somewhere has one on the shelf. I found one place on Ebay that advertised it in stock so I emailed them to confirm but who knows how long it will take to hear back from them.
Coupe, I used a TCI on my T-400 swap
butterbean- Posts : 676
TCI is fine with me. My biggest issue is I ordered it over a month ago. I KNEW then it had not been manufactured yet but was to be manufactured starting the 22nd of last month. With a ship date before 7/1/15. As of yesterday JW has not even began manufacturing these.. That's what I don't like.
Butter bean, do you have the part number? I only found ONE on Summit last night from TCI and it was for an internal balance setup. I am using an external balance setup currently.
mine is internal too, I'm on my way to Alabama (gmsmkr's) shop to finish the car and I will get you the measurements you need for the drive shaft and cross member,
That will be awesome. I spoke with AJE yesterday. Their Th400 cross member accepts the trans as long as the motor isn't set back any. Which from what I remember working with a big block car 10 years ago .... it wasn't So im going to order the TH400 cross member from them. I DO need t hat Driveshaft measurement though if you get a chance.
Thanks for the help fellas.
I have a tci and a jw but I am in Canada
56Tbird- BBF CONTRIBUTOR
» Any way to locate a car?
» Where to locate MECHANICAL temp sender?
» Need a wheel
» 429 Fly Wheel
» no more JW Wheel
» Need a wheel
» 429 Fly Wheel
» no more JW Wheel
