Where to locate MECHANICAL temp sender?
Where to locate MECHANICAL temp sender? Empty Where to locate MECHANICAL temp sender?
Post  Andre.servin March 14th 2017, 10:23 pm
Can't figure out where to mount my mechanical temp sender? The prong from the temp sender seems to be too long for the intake or thermostat housing.
Where are you guys positioning yours?
77 Ford 460
Andre.servin
Where to locate MECHANICAL temp sender? Empty Re: Where to locate MECHANICAL temp sender?
Post  rmk57 March 14th 2017, 11:04 pm
I've always installed them in the thermostat housing. They come with a special fitting that goes from male pipe to what type thread the sender uses, and that gives you another 1/2" or so extra depth.
rmk57
Post  Gregaust March 15th 2017, 5:13 am
Front of the intake beside the bypass hose
Gregaust
Double post Sad
Gregaust
Post  Andre.servin March 15th 2017, 7:20 am
Genius!!! Thanks gregaust
Andre.servin
Post  DeepRoots March 15th 2017, 7:10 pm
Greg's advice is easiest.
If you ever find yourself in a pinch, you can install it into a T in the heater core line. Routed downward and toward the back of the engine, it will not be seen.
I've had to do this on FE intakes that have very few coolant ports.
DeepRoots
