612" bbf timing
612" bbf timing Empty 612" bbf timing
Post  Hardy July 24th 2015, 6:38 pm
Hey guys, just looking for some thoughts from some of you who have experience with similar deals to see if we are on the right track. 612" (4.6x4.6), 6.8 rod, ~15:1 compression, profiler heads from TRE 528 cfm @ .900, sheetmetal intake with two prosyatems dominators on q16, cam I think is .890 lift and I want to say 288/306 @ .050 and I think 116 lsa. Just curious what to use for a starting point from timing, and where you'd guess it would perform best. Obviously, well test n tune to figure it out, but our builder thinks it should work well at 26-28*, my brother and I think 31-32* is more realistic. What you say?
Hardy
612" bbf timing Empty Re: 612" bbf timing
Post  BOSS 429 July 25th 2015, 12:11 am
either of those could be close, depending on how good the heads work with that cam,and intake,but really should dyno it
Post  kim July 25th 2015, 8:12 am
Because of the unique properties of Q16, 28-30 is probably going to be peak power. On non oxygenate fuel its probably best about 32.
kim
Post  Hardy July 25th 2015, 8:59 am
Interesting about the q16. I was thinking about that the other day and was thinking that Q would possibly require less timing, but I don't have the tuning experience to have seen it first hand. Appreciate the replies guys.
P.s. I definitely agree it should be dynoed and it will be this offseason.
Hardy
