TFS 325's to much
TFS 325's to much Empty TFS 325's to much
Post  slowjoe July 30th 2015, 4:42 pm
I have a 437 short block that I will be putting in my car to replace the stock 429. My plan is to do a 545 in a few years. How bad will the 325's and big TFS intake hurt the 437? I was hoping I could just swap them to the 545 when I have it and the car setup better.
slowjoe
TFS 325's to much Empty Re: TFS 325's to much
Post  dfree383 July 30th 2015, 4:45 pm
They will work ok, just make sure to use a looser converter, a little gears and don't go overboard in the cam.
Post  slowjoe July 30th 2015, 4:52 pm
After doing some reading on here It seems I can't turn the stock rods much over 6000 rpm. Was planning on have a custom cut solid roller for it. I am also planning on about a 150-200 shot sometimes.
slowjoe
Post  IDT-572 July 30th 2015, 4:58 pm
Any over headed engine you need to narrow the separation up on the cam. Put some overlap in it if your running it N/A.
If you are spraying it, go ahead and cam it like it was a 545-557. And spray tha bag off of it.
But if you have stock rods, you better run it N/A till you can get a set of good rods or the bigger engine.
