finally getting my race truck together . looking for any advice i can get
its a 80s f150 frame with a 82 ranger body on it firewall was notched to set the motor back .
now for the sadness..... it wont be bbf powered for right now i got a couple really good deals on some sbf parts so i will run a small block 408w motor till i can afford the big inch stroker i want truck will be on 38.5 cuts dana 44 front and 9 inch rear . looking at following frank merkels instructions on this and the other 460 site to a t to rollerize the c6 and add the clutches hopefully a merkel brake . but im super open to opinions and advice at this point starting with blank canvas
bigben- Posts : 52
Re: finally getting my race truck together . looking for any advice i can get
Old red truck and yellow one is new chassis red one was mainly a trail rig
attempt to post pics probably a fail
bigben- Posts : 52
Looking at tires was just gunna buy boggers front and rear but I'm seeing some of you guys are running cut tsls any info on why I seen a couple say big horse trucks well I'm running 12-24 inch deep stuff looking at makin 600 n/a with a 200 shot so are the cut tsls something I should run?
bigben- Posts : 52
looking at transmissions and got ??? what are guys using i have a c6 big block core that needs to be rebuilt but talking with some guys that run mra and cma stuff are saying build a glide even thought i'm running threw 12-18 in deep rough pits. i'm also hearing a lot of guys building glides as a single speed any ideas on this
bigben- Posts : 52
I run against guys with PG's and I don't feel like I give up anything with the C6. Mine is about as bullet proofed as it can be with a Merkl VB and billet drums. Not cheap the way mine is, but where you are at, it wouldn't need much. A good VB, drums, clutches, and rollerized and it will do fine. Lots cheaper too.
schmitty- Posts : 4538
Alright then I have another question do you still only run one gear threw the pass. Because I was thinking if I only use one why not go to a two speed I can get the adapter bell housing for 250 and my dad owns a machine shop so I can make the transfercase adapter . I guess I just assumed the pg is lighter an if I could make the run in one gear why not go glide save some weight
bigben- Posts : 52
I use 2 gears, 1st and 2nd, for now because that is how my trans brake works. How long are your pits?
bigben- Posts : 52
I use ALL 3 gears in my C6.
crittersf1- Posts : 521
crittersf1 wrote:I use ALL 3 gears in my C6.
You gonna get time to get that thing out this year?
kjett- Posts : 1169
we dont use trans brakes... one truck runs 1-2... the other truck only runs 2-3 with edge stall and in low range 208f.
racinghabbit- Posts : 575
» stock truck pull, finally!!
» Finally got the truck dirty
» finally got the truck out this year!
» Need some advice on a pro street truck build
» Fitted my engine into my truck,Finally!
