Line lock question
Line lock question
This may be a stupid ?but can you over power the line lock in the burn out with too much tire.....14 inch wide 2900 lbs and 550 hp to the rear wheels with skinny front tires.
airford1- Posts : 192
Re: Line lock question
Depends.....
Are we talking about over powering the front brakes (rolling the tire), or over powereing the front tire/ground contact patch (sliding the tire)? I have seen both.
It's possible for a car to have the line-lock hold the front brakes 100% locked tight, only to slide the front tires foward on the track surface. Sometimes it's from having a small front tire contact patch, or having some water under the front tires, or the slicks sitting in a dry water box.
If it's the front brakes not holding correctly (vs sliding the front tires), then that could be a problem with the brake system, (bad brakes, bad m/c, wrong m/c, m/c plumbed backwards, wrong pedal ratio, etc, etc) or a crap/weak/dead line-lock.
DILLIGASDAVE- Posts : 2262
Sometimes it's just a matter of trying to get too much burnout. The days of having to build a lot of heat in the tires are pretty much gone. Slick tire manufacturers will tell you to get them clean and dry, with just a little smoke. I'd say if you're happy with the way the brakes work at other places on the track, don't sweat it too much.
I'm constantly being told that I don't get a good burnout...yet the car hooks to beat hell every time. I start my burnout in high gear to get the tire speed up quickly (spinning them dry in low, then shifting is a good way to overpower the front brakes and/or skinny front tires.) and let it roll out.
I do my short burnout routine every time for 3 reasons:
1. I don't have any trouble getting hold of the starting line.
2. I'm not in the water box to impress anyone.
3. I'm the one who pays for new slicks.
Just my .02
Just my .02
maverick- BBF CONTRIBUTOR
Thanks . I am happy with the brakes and yes it front tires are skinnies with a small patch that is being over powered.
I like your style Maverick. The paint on your car is extreme
Jetman- Posts : 36
» MSD 6AL, line lock, tranny dipsitck, carb fuel line
» Line Lock!!
» my line lock no work
» Line lock knob
» Line lock Wiring.
» Line Lock!!
» Line lock knob
» Line lock Wiring.
