Which Alum Cylinder head?
gmsmkr
Harper 65
Which Alum Cylinder head? Empty Which Alum Cylinder head?
Post  Harper 65 August 18th 2015, 10:49 am
I am looking at Finally building a 460 for my 1965 Ford Pickup. I want a low 6 sec truck in the 1/8 mile yet i want it to be able to run upward of around 130-150 mph on top end. Transmission will be either a C4 automatic or possibly a lighter weight C6. my question is this,
which alum cylinder head is best for around 600 hp NA. I do plan to add some Nitrous but i want that to be in addition to what i will have NA.
Specs include
stock crank, eagle rods, after market pistons, Roller Cam/Lifters, Roller rockers, electric water pump, Engine Plate, not sure on the gear in the rear end yet.
I have ran the Ford port blue Thunders in the past and liked them, made around 600 hp with those, but to my understanding the Kaase P51 heads are supose to be better??
thanks in advance.
Harper 65
Harper 65
Which Alum Cylinder head? Empty Re: Which Alum Cylinder head?
Post  gmsmkr August 18th 2015, 11:02 am
The frpp scj or p-51 will be a good choice for your need... sounds like a fun build
gmsmkr
gmsmkr
Post  Harper 65 August 18th 2015, 11:07 am
I am hoping so. I have been out of going to the track for a long while (Raising kids etc), so hopefully it will be something me and my boys can work on together, play at the track together and the best part is shut a few mouths around here that tend to be more on the shevy side of the fence and honestly get quite annoying at times lol
Harper 65
Harper 65
Post  gmsmkr August 18th 2015, 11:19 am
Harper 65 wrote:I am hoping so. I have been out of going to the track for a long while (Raising kids etc), so hopefully it will be something me and my boys can work on together, play at the track together and the best part is shut a few mouths around here that tend to be more on the shevy side of the fence and honestly get quite annoying at times lol
Working with the kids is the best part pay them with ice cream Razz
My 6yr old helping with a 2 valve mod motorWhich Alum Cylinder head? 20150807_183211_zps5nhhivnp
gmsmkr
gmsmkr
Post  Harper 65 August 18th 2015, 11:24 am
now thats awesome.
I really should break into the Mod Motor deal soon, but i just havent yet.
Harper 65
Harper 65
Post  maverick August 18th 2015, 12:57 pm
Is this engine going into a stock chassis?
Post  dfree383 August 18th 2015, 4:53 pm
You gong to need more than 600hp to make a factory truck chassis go that fast.
But P51s with some compression and a roller cam will get you well over 700 at 466"
Post  maverick August 18th 2015, 6:27 pm
maverick wrote:Is this engine going into a stock chassis?
I wasn't asking in regard to hp requirements. I was trying to imagine driving a '65 F100 upwards of 130 to 150 mph. Without some major chassis and aero upgrades, that might be more of a ride than planned. Shocked The last time I drove one of those, 85 mph was plenty thrilling. Wink Turns out that leaf springs, Twin-I-Beams and the aero of a barn door weren't aimed at the superspeedway.
Post  gmsmkr August 18th 2015, 6:31 pm
Razz Razz you mean you wouldn't want to run 130 plus in a old truck on stock suspension
I think this ol truck could use a C/V swap front end and a coil over rear with ladder bars
gmsmkr
gmsmkr
Post  supervel45 August 18th 2015, 6:56 pm
I don't usually say this, but for what you want to do a stroker kit makes a lot of sense.
Post  maverick August 18th 2015, 7:03 pm
supervel45 wrote:I don't usually say this, but for what you want to do a stroker kit makes a lot of sense.
Yup.
Post  bruno August 18th 2015, 8:04 pm
Yup.
x2 and some P51 ..... Wink
http://WWW.CKRME.COM
Which Alum Cylinder head? Empty had a 68 f100 bbf
Post  mpinder18 August 18th 2015, 8:13 pm
Drove a bbf 68 F100 for years back in the day, a real hand full. Update the front to a rack, disc brakes the rear with a ladder or 4 link and get it low.
mpinder18
mpinder18
Post  maverick August 18th 2015, 8:33 pm
Very low.
Post  Lem Evans August 18th 2015, 8:57 pm
Flat tappet or roller cam ?
Post  mpinder18 August 19th 2015, 9:44 am
Lem Evans wrote:Flat tappet or roller cam ?
Mine was flat tappet. If your after big numbers then go roller. It is expensive but any motor going fast is. I ran MSD with a rev limter long ago so I had no problems with flat tappet. What ever cam you choose I would go with a custom grind. Parts for bbf fords were not around wide spread in the 1980 an 1990 so you get custom set up now easy.
mpinder18
mpinder18
Post  mpinder18 August 19th 2015, 9:59 am
[quote="Lem Evans"]Flat tappet or roller
Go aftermarket heads, lots of years of development are done.
mpinder18
mpinder18
Post  butterbean August 19th 2015, 12:34 pm
I know the old truck is cool but for how fast you wanna go I would find a older Ranger and gut it and put the BBF in it, you will be way ahead in the weight category, or a stroker and a front clip will get you there too!!!! happy building
butterbean
butterbean
