Will truck 460 Exhaust manifolds work in 70 torino?
Andre.servin
Will truck 460 Exhaust manifolds work in 70 torino? Empty Will truck 460 Exhaust manifolds work in 70 torino?
Post  Andre.servin August 18th 2015, 4:57 pm
Got a 460 in my 70 torino, I was going to go with headers but dont want any bottoming out over speed bumps. I would go with shortys but to be honest, headers for this swap are kinda pricey.
I was wondering if truck 460 exhaust manifolds will work?
The manifolds will be less maintenance, less leaking (if any), more quite.
Does anyone know if it will work? any specific years required?
Andre.servin
Will truck 460 Exhaust manifolds work in 70 torino? Empty Re: Will truck 460 Exhaust manifolds work in 70 torino?
Post  rmcomprandy August 18th 2015, 5:18 pm
Andre.servin wrote:Got a 460 in my 70 torino, I was going to go with headers but dont want any bottoming out over speed bumps. I would go with shortys but to be honest, headers for this swap are kinda pricey.
I highly doubt it.
Call Stan at 1 800 962-6467
Post  Andre.servin August 18th 2015, 5:33 pm
stan makes headers??
Andre.servin
Post  dfree383 August 18th 2015, 6:53 pm
Andre.servin wrote:stan makes headers??
Yep..... Stan make shorty headers to fit a Torino.
Post  rmcomprandy August 18th 2015, 7:50 pm
I believe he has some mid-length Tri-Y headers for that application, also.
Post  BOSS 429 August 18th 2015, 8:59 pm
no, use some from a thunderbird, thunderjet n code,its what was used on non cj scj torinos till 72
the rh truck turns out way too much
Post  FalconEh August 18th 2015, 9:21 pm
BOSS 429 wrote:no, use  some from a thunderbird, thunderjet n code,its what was used on non cj scj torinos till 72
^^^^^^ X2 on the Bird, but what kind of motor do you have because most exhaust manifolds will choke a performance motor to the equivalent of a smogger motor with mediocre performance and crappy gas mileage. Also is it manual or power steering...if it is manual you will have more header clearance without the PS ram, if it is power you can get a drop bracket for the PS ram and make room for the headers.
Post  Andre.servin August 20th 2015, 7:05 pm
Okay cool sounds good I will call Stan.
Yea im making the engine a solid low maintenance daily driver 460.
So it's stockish but has a nice Holley double pumper, a mild cam, and I wanted to put headers on it to help with more breathing.
I will look around for some headers. I don't think I will find any exhaust manifolds for it. Simply because I know I can find a 460 in a truck at the wrecking yard to take them from but an old thunderbird? No way. At least not where I'm at.
Andre.servin
Post  The Mad Porter August 21st 2015, 1:55 pm
Andre.servin wrote:Okay cool sounds good I will call Stan.
Stan Johnson has a mid length header specifically for that application.
www.fordpowertrain.com
253-848-9503
Will truck 460 Exhaust manifolds work in 70 torino? <a href=Will truck 460 Exhaust manifolds work in 70 torino? Mvc-0111" />
Last edited by The Mad Porter on August 21st 2015, 2:01 pm; edited 1 time in total (Reason for editing : Add pic)
The Mad Porter
The Mad Porter
Will truck 460 Exhaust manifolds work in 70 torino? Empty manifolds
Post  gary o September 1st 2015, 11:56 am
The truck manifolds will indeed work in your 70 torino-I have a set in my 71 ranchero and the fit just fine-good luck on your project!
gary o
