EFI heads+70's truck exhaust manifolds?
Ok, I'll get to the point, I recently came back around to doing a '78 fullsize bronco and plan on putting a 460 in it. I got a 460 out of a '92 F350 for my build, and my question is this.
Will exhaust manifolds from a '70s truck bolt on to my EFI heads?
this is sort of a budget build, I just would rather not put headers on it.
prosandguy- Posts : 186
Re: EFI heads+70's truck exhaust manifolds?
The bolt pattern is the same, however the port shape is not. Therefore, the carb exhaust manifolds will not seal. Use the 460 FI manifolds.
Thanks for the knowledge Paul, I was afraid you were going to say that.
» Will truck 460 Exhaust manifolds work in 70 torino?
» 429 PI exhaust manifolds
» CAST IRON EXH.
» 430 mel exhaust manifolds
» Are exhaust manifolds really that bad?
» CAST IRON EXH.
