cam change what to expect
+21
69BOSS
Straubtech
zbob
gt350hr
whitefield
AZFairlane
f250mike
kim
Inthegarage
YellowStangDuane
DaveMcLain
25 posters
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
cam change what to expect - Page 3 Empty Re: cam change what to expect
Post  rmcomprandy September 20th 2015, 10:33 am
zbob wrote:yes randy reality set in. what I came to appreciate is this is still a fully streetable, power brake equipped, muffled, idling, decent engine temped car I can use and drive ......bob
super, yes still have the 327 gears. gear changes and a plate kit is a winter time goal. its fall in northern Minnesota. time for outside get ready for winter chores. fwiw should have got a small cell a long time a go.....bob
You got an increase of about what I expected for your combination.
Keeping it "fun to drive" is a lot of what this is all about; unless it is an all out race car.
Post  Straubtech September 21st 2015, 9:57 am
zbob wrote:gentlemen, tired of high 12s want low 12s.
..... edelbrock rpm heads 75 cc, torker ii intake, proform 850 street carb, shorty headers, 327 gears with 26 tall tires.  two ton pistons 5 in the hole,
.....cam is a wuss cam 213 219 520 lift. gonna try a 274 voodoo cam. I believe it is 227 230 and 560ish lift. I  need enough vacuum for power brakes. ability to drive around minn wisc etc is important to me. will the cam change get it done? thanks bobn
If the board want to see it and your willing I will design a custom camshaft based the engine combo and the goals. Here is my only stipulation. You pay for the cam when I send it. Once you test it no matter the results I refund you the money for the camshaft. Offer is on the table.
Straubtech
Post  rmcomprandy September 21st 2015, 10:18 am
Straubtech wrote:
supervel45 wrote:I was going to mention, I want to see the dyno pull start as low as possiable, like under 2,000 Rpm so we can compare down low numbers. Almost everyone looks at the peak HP when cam shopping.
Won't happen on the dyno stuff.  Most dyno shops have water brake units.  A water brake dyno below 3500 rpm is not accurate due to the absorber and how it works.  Now Ford has a few that will test them but most engine shops don't drop a few million on just a dyno.
Just about ANY electric dyno like a GE, Westinghouse or Froude will pull a 1,000 lb/ft diesel down easily.
Katech has 3 of 'em and they are within walking distance for me.
Post  supervel45 September 21st 2015, 12:38 pm
That would be fun to do some tests with. I would like to see some of the old single pattern cams run against all this new stuff just to see how they compare. Not a lot of dyno charts on the 460's at least compared to the SBC's. I am not trying to put anyone's cams down, I just would like to compare them with a basic stock engine and heads, with headers, dual plane intake and 750/850 carb. Most of the dyno stuff is more race oriented it seems. ZBobs test is very not subjective as it has too many variables, still waiting on 60ft and 3.30 times with the old one to compare. Also his observations of how he likes the cam change on the street as for as overall performance, compared to the old cam would be nice to.
Post  zbob September 21st 2015, 10:03 pm
pm sent. straub....thanks bob
zbob
Post  f250mike September 22nd 2015, 9:52 pm
Well Bob, Straub has laid down a challenge.
I know what you've done with a pile of bolts and happy that it's always improving.
We know each other's rides like their our own and I wouldn't pass up Straubs offer if it was me.
I want to see the Zephyr in the 11's!!!!!!!!!!!!!
f250mike
f250mike
Post  Straubtech September 23rd 2015, 9:17 am
f250mike wrote:Well Bob, Straub has laid down a challenge.
We have started the ball. Bob is going to call and we get the details worked out.
Straubtech
Post  supervel45 September 23rd 2015, 9:50 am
So no other changes except a cam swap?
Post  IDT-572 September 23rd 2015, 11:43 am
I would like an offer like that............... Cool
Post  Straubtech September 23rd 2015, 12:39 pm
Over the years I have not sold cams to customers who have called to change cams. If the stick in the car is fairly close to what is optimum and we can get there with a lash adjustment and maybe some cam phasing then I give the guy that info. I won't sell someone something they don't need. Now if the cam is going to make a difference I will give you a % of increase and the customer can decide if the increase is worth the money spent.
Straubtech
Post  supervel45 September 23rd 2015, 12:49 pm
Do you have any idea yet what the percentage increase will be that Bob will pickup over the Lunati he has now with a custom grind, and are we talking peak HP or E/T's?
Post  Straubtech September 23rd 2015, 12:57 pm
supervel45 wrote:Do you have any idea yet what the percentage increase will be that Bob will pickup over the Lunati he has now with a custom grind, and are we talking peak HP or E/T's?
yes I do, but in the era of "Internet Lore" I would rather stay quiet and let Bob's results do the talking.
Straubtech
Post  zbob September 23rd 2015, 5:49 pm
and bob is wise enough not to share intelctual information. bob
zbob
Post  supervel45 September 23rd 2015, 6:28 pm
OK LoL
Post  cletus66 September 24th 2015, 2:13 am
This should be fun. Good thread. Cool
Post  supervel45 September 24th 2015, 10:21 pm
http://www.straubtechnologies.com/ Those SCJ iron numbers look nice. Cool
Post  Straubtech September 25th 2015, 10:16 am
supervel45 wrote:http://www.straubtechnologies.com/        Those SCJ iron numbers look nice. Cool
yes he got torn down quite a bit when it first went out on the OH pulling circuit. I will post the results of this Thor headed 610CID in a few weeks. It is 17 to 1 on Alky.
Straubtech
Post  Straubtech September 25th 2015, 10:19 am
zbob wrote:pm sent. straub....thanks bob
the work begins!!!
Straubtech
Post  f250mike September 29th 2015, 10:45 pm
Good luck guys!
I may need a new cam once my $ sucking ranger project is done
f250mike
f250mike
Post  f250mike September 29th 2015, 10:47 pm
Good luck guys!
f250mike
f250mike
Post  AZFairlane September 29th 2015, 11:39 pm
Buy mine and you can see one in the 9's Very Happy
AZFairlane
AZFairlane
Post  zbob September 30th 2015, 10:38 pm
hey joe will a dollar two ninety eight cover it? thanks bob
zbob
cam change what to expect - Page 3 Empty first local event tommorow.....cam from struabtech
Post  zbob May 13th 2016, 10:09 pm
new year is here first local event at siren airport 1/8 fun and games. hope she runs good. bobn
zbob
Post  zbob May 14th 2016, 5:51 pm
8.3 at 86 in the eight. 2 tens faster. engine runs cooler too. drove the car there and home. so the straubtech cam is better yet than the last change.  thanks chris.....bobn
zbob
Post  whitefield May 14th 2016, 8:00 pm
[quote="zbob"]8.3 at 86 in the eight. 2 tens faster. engine runs cooler too. drove the car there and home. so the straubtech cam is better yet than the last change.  thanks chris.....bobn[/quote
edit pretty good pick up just with a cam only !
whitefield
whitefield
