Rocker arm roller
Rocker arm roller Empty Rocker arm roller
Post  460bronco August 27th 2015, 10:14 am
Hello All-
I recently had a hardened tip come off of one of the exhaust valves in my SCJ heads... When this happened, my rocker arm rode on the retainer for a short time. This wore an area in the aluminum of the rocker body....
So, I got the head fixed and figured I would replace the rocker arm. I am running the Trick Flow Blue Ford 1.73F rocker arms.
When I got the new single rocker arm out of the package and compared it to my old ones, it looked like the roller tip was a little larger than my old rockers. I measured an old roller and it measured in the .480" range and the new one was actually larger. It measured .520"
Will this difference in roller diameter cause any problems?
Jon
460bronco
460bronco
Rocker arm roller Empty Re: Rocker arm roller
Post  supervel45 August 27th 2015, 2:03 pm
If my calculations are correct, it would only change the pushrod side .011". .520-.480= .040 divided by 2= .020 divided by 1.73=.0115". My math may be all wrong though, but I think it would be OK to run it. Wait and see what Randy and the rest of the guys say, though.
Post  cool40 August 27th 2015, 2:24 pm
Run it!
Post  gt350hr August 27th 2015, 2:50 pm
cool40 wrote:Run it!
+1 run it!
gt350hr
Post  460bronco August 27th 2015, 6:08 pm
Thanks for the replies guys!  Valves are adjusted and stud girdles on! cheers
460bronco
460bronco
