roller rocker 1.73 bbf a460?
+10
racerk_2000
mico
Larry T
DJOHAGIN
fastford600
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
i have been told that the reg 1.73 rockers will not work on my a-460 heads
is this true? if so were do i get the right ones?
logan
logan
fastford600- Posts : 391
Re: roller rocker 1.73 bbf a460?
A Chebby lover must have told you.
LOL.
The A-heads can use the rockers no problem.
and it's Monday.
Dave
LOL.
and it's Monday.
Dave
DJOHAGIN- Posts : 91
oh spit are you 100% sure? if so i just messed up.just sold a new pair because thay said thay would not work.lost my ace!!!!!!!!!
Sorry, friend, it is true, but look at it this way: Now you can buy some real good rockers. Take a look at Terra Yella rockers.
Hope that helps,
Dave
Hope that helps,
Dave
[quote="DJOHAGIN"] Take a look at Terra Yella rockers.
i have never heard of these tell me about them or give me a link
http://www.yellaterra.com/
i have them on my cylinder heads ...... pedestial mount
here ya go dig around in the web sight and find them for your app.
http://www.yellaterra.com/products/car-performance/product-detail/roller-rockers.cfm
Larry T- Posts : 1076
I bought a set of Crower stainless steel 1.73 rockers for my A460's. I don't think you can get a better stud mount rocker arm. Bought mine from Lem Evans.
[quote="David Cole"]I bought a set of Crower stainless steel 1.73 rockers for my A460's. I don't think you can get a better stud mount rocker arm. Bought mine from Lem Evans.
cost?
cost?
[quote="Larry T"]here ya go dig around in the web sight and find them for your app.
cost?
cost?
i want a good set but money around my house is like finding a hens nuts!!!!!!!
you may not wana know about crowers then.LOL,mine were 399 about 5yr ago.
I dont think all BBF 1.73 rockers will work with the spring dia. on A heads. I used the Crane Gold rockers on my TFS A heads.
mico- Posts : 33
[quote="mico"]I dont think all BBF 1.73 rockers will work with the spring dia. on A heads. I used the Crane Gold rockers on my TFS A heads.
THAT IS WHAT I WAS TOLD ALSO .A SET OF BLUE ROCKERS DID HIT ON MY FRIENDS HEADS BUT I DID NOT KNOW THIS UNTIL 20 MINS AGO
SO DOES ANYBODY KNOW WHAT TYPE WILL WORK? I DONT WANT NO T&D'S FOR SURE ,NO WELDING ON PEDS FOR ME.DID THE CRANE GOLD HIT? DOES TFS SELL ON FOR THAT HEAD?I AM LOST.I NEED HELP ASAP . BEFORE I BUY SOME JUNK.
crower's will for sure,you'd better find some hen nuts!LOL
Logan,
I'm sorry I did not see this post before. To answer your question, any true 1.73 ratio stud mounted rocker arm designed for the Fords will work with your A-460 heads. Years ago, Lem and I did a lot of checking (and measuring the lift at the retainer), and it seems that the Crane Gold, Ford SVO Blue, TFS black, and Lunati blue are all pretty much the same rocker arm. In addition to those four, we like the Comp Cams stainless steel rockers, the Probe rocker arms and the Crower rocker arms. We also very carefully checked a set of Yella-Terras and believe it or not, we never could get the lift at the retainer that the rocker arms were suspossed to give, and that was shimming correctly and using various length pushrods. We did not like the Yella Terra rockers.
I "think" Lem carries the Probe, the TFS, the Lunati, the Ford and the Comp Cams rocker arms in stock. Double check with Shawn in the parts dept. In addition to the above, we love the Jomar rocker arm stud girdles.
Hope this helps,
Charlie Evans
Hope this helps,
Charlie Evans
c.evans- BBF VENDOR SPONSOR
2X what they said about the crower rockers. More inital investment, but they last forever. We ran them on out circle boat at 7200-7400 rpm, 5 mile race plus 5 minute warm up. 4 racing heats a weekend and 12+ races a year. Ran them for years with zero problems. I have not done the math but I know it is a lot of cycles. We even flipped the boat during a race in Key Largo , the engine was full of salt water. We drained it and soaked everything in oil but several of the roller bearings rusted. We just replaced the bearings and were back in business. I feel they are a good investment.
Kevin
Still Stuck in Kirkuk Iraq
Kevin
racerk_2000- Posts : 88
mico wrote:I dont think all BBF 1.73 rockers will work with the spring dia. on A heads. I used the Crane Gold rockers on my TFS A heads.
You think wrong ... if you can use big sporings with those rockers on REGULAR heads then they will also fit on A460 heads.
It's about whether or not the rocker is clearanced for big diameter springs. If that rocker interferes with big springs then they would have interfered on regular heads also if big springs were used.
FRPP aluminum SCJ heads on the intake side are the only exception; they have LESS clearance.
Crane Gold, FRPP, Trick Flow and early Lunati are all the SAME manufacturer rocker arms.
c.evans wrote:Logan,
Hope this helps,
Charlie Evans
i have the jomar stud girdles thay are gold.
is there a hp limit on any of these rockers? i was told if you make over 1100 hp you need to run shaft rockers.
rmcomprandy wrote:mico wrote:I dont think all BBF 1.73 rockers will work with the spring dia. on A heads. I used the Crane Gold rockers on my TFS A heads.
Not trying to get in a pissing match, I was just trying to tell the guy that some rockers won't clear the springs on A heads. Not sure how the regular heads came up?
mico- Posts : 33
well look at this the rockers off the old 521 cj514 victor jr headed motor will not work on my a-460.
why is this? just my luck!!!!!!!!!!!!!!well i hope the rest fits
logan
logan
what is the brand from the 521 that won't work ? why do say the T&D need the ped. welded ?fastford600 wrote:well look at this the rockers off the old 521 cj514 victor jr headed motor will not work on my a-460.
logan
DanH- Posts : 1081
the builder told me that you need to weld the peds to keep them from moving arond.
i aint no motor builder but i did see what he was talking about and it is just a added safety.
i think that it is only held with only one bolt per rocker .
i dont rem. the brand
logan
logan
when you said peds, i was thinking -- welding the head peds. welding the Stands is no big thing. Jesel bolts the stands to each other
DanH- Posts : 1081
Page 1 of 2 • 1, 2
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Rocker arm roller
» converting to roller rockers on C8VE heads
» Roller rocker damage
» Roller rocker choices . Which one
» Rocker arm roller
Page 1 of 2
