roller rocker 1.73 bbf a460?
+10
racerk_2000
mico
Larry T
DJOHAGIN
fastford600
14 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: roller rocker 1.73 bbf a460?
i found out what brand of rockers thay are hartland sharp thay hit at the top of the spring when you roll the motor over.
logan
logan
fastford600- Posts : 391
fastford600 wrote:i found out what brand of rockers thay are hartland sharp thay hit at the top of the spring when you roll the motor over.
logan
I just had to do some minor clearancing on my Harland Sharps to clear the big springs. Not saying they are the best, but they work for me.
kjett- Posts : 1169
lem i have no idea how long thay are?
fastford600 wrote:lem i have no idea how long thay are?
That could be the problem. Have you actually checked the rocker arm geometry? If not, get an adjustable pushrod and do some checking. Sounds like incorrect pushrod length could be the culprit.
Nevs- BBF CONTRIBUTOR
i was not building it this was just on my friends motor a few weeks ago that why i asked about the rockers
this man builds motors all the time for other people not mine i just did not want to in to that when the build starts
in a few days
logan
in a few days
logan
Well one common mistake is for guys to buy and use 1.70 ratio big block Chevy rockers, on our Fords. While it can be done, often times the geometry is less than perfect. The reason Lem asked about the pushrod length, is because too long of a pushrod, will make a stud mounted rocker roll off the outer edge of the valve stem. So therefore, having the correct pushrod length is vital for proper rocker arm geometry.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Page 2 of 2 • 1, 2
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Rocker arm roller
» converting to roller rockers on C8VE heads
» Roller rocker damage
» Roller rocker choices . Which one
» Rocker arm roller
Page 2 of 2
