solid axal 95 bronco
solid axal 95 bronco Empty solid axal 95 bronco
Post  Bart Knox August 30th 2015, 10:07 pm
Looking for a 79 bronco or f150 for a front axal to swap into my 95 bronco I have a line on a few doner trucks what parts am I going to need to perform this swap I wasn't sure about the steering hooking up steering box and power steering I already have the older stile power steering pump hooked up in my bronco I can handle mounting the axal just wondering about hooking everything up
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
solid axal 95 bronco Empty Re: solid axal 95 bronco
Post  kjett August 31st 2015, 8:18 am
Your 95 box will work fine. I did the SAS on my 95 f-150 and it's not that hard. if you want to go all "stock" parts, you will need the axle, radius arms, and radius arm brackets. You will need to fabricate a track bar bracket for the frame side. The 95 upper coil/shock buckets will work fine. Keep in mind that the 95 has that low jung crossmember, so a minimum of 4" lift coils will be needed. Lastly steering, the late 70's tie rod will work, but you will need to make a drag link to fit from your box to the tie rod. I've read that the f250 drag link will fit, but never tried it. I just went and got chromoly tube, inserts, and heim joints and went that route. Hardest part of that is reaming out the knuckles to remove the taper. There are places that sell the kits with the 2 tubes close to length if you google it.
kjett
kjett
