Hose between intake and water pump
Hose between intake and water pump Empty Hose between intake and water pump
Post  460bronco September 17th 2015, 8:26 pm
Whats it for? And do you have to run it?
460bronco
460bronco
Hose between intake and water pump Empty Re: Hose between intake and water pump
Post  rmcomprandy September 17th 2015, 9:45 pm
460bronco wrote:Whats it for? And do you have to run it?
It is a by-pass to relieve water pressure when the thermostat is closed so, you don't blow open the heater core. Race type vehicles don't need a water by-pass.
Post  69F100 September 18th 2015, 12:02 am
I just finished putting my intake back on I know the next time I pull the engine for a for a freshen up I going to weld a plug in the outlet on the water pump. That Little peace of hose it the hardest thing to get on for sure.
Post  460bronco September 21st 2015, 11:57 am
Thanks for the replies.  The ports are now blocked off cheers
460bronco
460bronco
