Trick flow intake water hose fitting
kim
Trick flow intake water hose fitting Empty Trick flow intake water hose fitting
Post  jasonf March 13th 2015, 2:04 pm
Does anybody happen to know where I can get a fitting for the bypass hose on a trick flow track heat intake manifold?
Trick flow intake water hose fitting Intake%20fitting_zpssun75cab
Trick flow intake water hose fitting Empty Re: Trick flow intake water hose fitting
Post  kim March 13th 2015, 3:58 pm
Tap it and use a 3/8 or 1/2 brass barb.
kim
Post  dfree383 March 14th 2015, 2:58 am
TFS or edelbrock offer the press in fitting.
Post  jasonf March 15th 2015, 10:54 pm
It is threaded already but by the time I put a big ol brass barb fitting on there there will be no room left.
Post  Doug Rahn March 16th 2015, 5:22 am
Try here http://www.mcmaster.com/#standard-barbed-hose-fittings/=wbxx9b they also have 45 & 90 degree fittings. You could probably cut some off the length if need be. Also in stainless if you want that.
Post  Doug Rahn March 16th 2015, 6:35 am
You might also try Dorman, they have all kinds of OEM fittings.
http://www.summitracing.com/parts/rnb-56358/overview/
Post  jasonf March 16th 2015, 9:25 pm
You're the shit Doug. Thanks for the links.
Trick flow intake water hose fitting Empty water byepass
Post  gas6999 March 20th 2015, 7:20 am
we tap them and put a hose barb in the [brass] then you never have to worry about those cheap stock ones again.
gas6999
Post  tfsbbf466 April 5th 2015, 1:19 pm
I have a barb threaded fitting in both the water pump and the intake. It's a nightmare to install the hose but can be done. I boil it in water and bend/ push it on while it's still soft and hot.
tfsbbf466
