Trick Flow A-460 intake water inlet ?
79Puller
I need some help with what water neck will work with the Trick Flow A-460 intake. This is the intake that has the inlet facing forward not straight up. I need a 90 degree inlet housing . I have tried two from a 351 and they dont fit. Thanks
79Puller- Posts : 193
Re: Trick Flow A-460 intake water inlet ?
302 / 351 W stuff fits.
Maybe it is the housing itself then, One 45 degree fit but hit the water pump and 90 would not sit flush like its surface was off. I guess I will try another one.
call Keith @ KFM ...he builds them !!!
Jesse,text me tom morn and I will see if I have one . I will forget if you don't remind me. What was it i was gonna look for again?79Puller wrote:I need some help with what water neck will work with the Trick Flow A-460 intake. This is the intake that has the inlet facing forward not straight up. I need a 90 degree inlet housing . I have tried two from a 351 and they dont fit. Thanks
![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif)
ok, thanks can I get that number
I used one from Mr gasket. Had to clearance the water pump to make room.
norm- Posts : 257
bruno wrote:call Keith @ KFM ...he builds them !!!
I second that
![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png)
John Myrick- BBF CONTRIBUTOR
» Trick flow intake water hose fitting
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» 2X4 TRICK FLOW INTAKE
» TFS Dual Plane?
» Trick Flow Intake
» TFS Dual Plane?
» Trick Flow Intake
