Trick Flow intake sizing
Part number TFS-53400112
Does anybody happen to know how big of carburetor blade this intake will accept in a box stock fashion?
Have a potential opportunity to borrow one of these intakes to test in application but am beginning to wonder if the carb and spacer will match up as the current Victor required significant material removal to accept.
EverySparePenny- Posts : 114
Re: Trick Flow intake sizing
I have put a Terminator 2100 CFM throttle body (2.5 blades) on mine and no interference. its close so check everything no matter what you are doing.
69bluehotrod wrote:I have put a Terminator 2100 CFM throttle body (2.5 blades) on mine and no interference. its close so check everything no matter what you are doing.
That is very good to know thank you. I'm at 2.375 if I remember correctly, and of coarse plan to check for interference. Didn't want the guy to bother sending it if there was no way it would fit without grinding on.
EverySparePenny wrote:69bluehotrod wrote:I have put a Terminator 2100 CFM throttle body (2.5 blades) on mine and no interference. its close so check everything no matter what you are doing.
The size throttle bore it will accept is greatly determined by the throttle bore center-line distances.
rmcomprandy wrote:EverySparePenny wrote:69bluehotrod wrote:I have put a Terminator 2100 CFM throttle body (2.5 blades) on mine and no interference. its close so check everything no matter what you are doing.
X2 I'd assume you'll need to clean up the corners a little bit to be safe a 2.375 on a dominator. I do know 2 1/4 fits.
The size throttle bore it will accept is greatly determined by the throttle bore center-line distances.[/quote]
X2 I'd assume you'll need to clean up the corners a little bit to be safe a 2.375 on a dominator. I do know 2 1/4 fits. [/quote]
I was unaware of that as a factor. Thank you for bringing it to my attention.
I wish the A head intake cleared like that. I will need to either taper a spacer or hog the throat out to fit a 2100 cfm terminator on my brand new TFS intake.
kjett- Posts : 1169
kjett wrote:69bluehotrod wrote:I have put a Terminator 2100 CFM throttle body (2.5 blades) on mine and no interference. its close so check everything no matter what you are doing.
Oakley has an app for that... having mine for the A-heads done by him...
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» TFS Dual Plane?
» Trick Flow Intake
» 2X4 TRICK FLOW INTAKE
» NEW Trick Flow A460 intake
» TFS Dual Plane?
» Trick Flow Intake
