Combustion Chambers
Combustion Chambers Empty Combustion Chambers
Post  TRUKPULR September 24th 2015, 5:08 pm
To those in the know.
I bought a Motor last year that has Ford Motorsport A-heads on it. And I have the Trick Flow A-heads I bought from C. Evans. My question is are the combustion chambers the same on these heads. I'd like to put my Trick flow heads in the motor Seeing how they have all the port work done to them, the Ford Motorsport head don't have any porting done to them at all, other then gasket matching. Will the pistons work or do I have to order new ones to match the Trick flow heads?
Dan Homa and ShaZam
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Combustion Chambers Empty Re: Combustion Chambers
Post  Lem Evans September 24th 2015, 6:15 pm
The TFS 87cc machined and 91cc as cast chambers should use the same dome foot print as the older SVO A460 stuff.
Just use some clay to check for sure.
