combustion chamber softening
10SHOTS
I have spoke with 3 different company's that does this , one does a 3 degree cut , one a 7 degree And the other a 10 degree , what degree cut do you nitrous guys use ?
10SHOTS- Posts : 587
Re: combustion chamber softening
No cut.... That .110 quench tho.....
Lem Evans wrote:Did they ask what cylinder head you have?
yes sir
talk with charlie buck of buck racing.
Larry T- Posts : 1076
I did , $800 v/s everyone else's $300 ,Larry T wrote:talk with charlie buck of buck racing.
I talked to BES , champion performance , fast forward and RFD Curtis Boggs
bes does the 3 , champion and RFD does the 7 and fast forward race engines does the 10
10SHOTS wrote:Lem Evans wrote:Did they ask what cylinder head you have?
yes sir
I was wondering.....do they use different angles depending on head style or is it a one size fits all kind of deal?
[quote="Lem Evans"]
I was wondering.....do they use different angles depending on head style or is it a one size fits all kind of deal?[/quote
the way I understood it was they won't to leave a .200 quench pad from the bore size . how deep they go before with the cut I don't know
yes sir
fast forward told me that on a 3 degree the next mill job would probably cut that out and that the 10 degree is more affective
I failed to ask if it would even be worth doing on a 350 to 400 shot , a lot of stuff I read people are doing this on multiple kits to help the engine live
10SHOTS wrote:Lem Evans wrote:10SHOTS wrote:Lem Evans wrote:Did they ask what cylinder head you have?
yes sir
One degree doesn't take but .0175" per inch. So, starting .200" off the bore and going but 3* would not get one much on a chamber like the SCJ deal on the right.
Lem, you're getting soft chambered in your old age.
Curt- Posts : 2791
Curt wrote:Lem, you're getting soft chambered in your old age.
Naw....I'd just jack the piston down in the hole
yes the 3* cut is a waste of money with the big shots of nos.the 10* or bowl cut is what most use in combonation of droping the piston in the hole for the big nos shots.
Larry T wrote:yes the 3* cut is a waste of money with the big shots of nos.the 10* or bowl cut is what most use in combonation of droping the piston in the hole for the big nos shots.
what's considered big shots ?
above 3-400 shot
got Another piston last night , buying Pistons is getting old ,
race gas is a little cheaper than aluminum. Might want to add a little fuel.
kim- Posts : 700
» Chamber softening
» Chamber softening
» combustion chamber shape
» Combustion chamber efficiency on 325 power ports?
» Combustion Chambers
» Chamber softening
