Chamber softening
Chamber softening
So ive been reading into softening chambers for boost. Has anyone had sucess with edelbrock performer heads. I know i cant take too much because of thin spots into water. they already have bowl and some port work. Seaing about opening it up to a felpro standard gasket, smoothing out and opening up what i can should help flow and lower compression a it as well as slow flame front to open tunning windows.
litshoot- Posts : 103
Re: Chamber softening
i have done this to a set of C460 heads with a pro-charger...and a nos powered 351c cleveland...
seems to work pretty good on the 351 it can run a little more timing without detonating we are putting 400hp of nos into it...the C heads i will let you know in a couple of weeks when i get it back into the car and run it again..
procharger 528- Posts : 45
» Chamber softening
» combustion chamber softening
» What does the chamber tell you?
» IDT's new 1400-1500 heads?
» combustion chamber shape
