460 Efi intake swap
460 Efi intake swap Empty 460 Efi intake swap
Post  wk.ross September 26th 2015, 10:56 am
Can I remove the intake manifold off a 1989 Efi 460 and swap a 4BBL aftermkt intake so I can run carb and reg distributor? I saw once awhile back an adapter to use on factory efi man, to adapt holley flange 4bbl. Any ideas?
wk.ross
460 Efi intake swap Empty Re: 460 Efi intake swap
Post  rmcomprandy September 26th 2015, 10:57 am
wk.ross wrote:Can I remove the intake manifold off a 1989 Efi 460 and swap a 4BBL aftermkt intake so I can run carb and reg distributor? I saw once awhile back an adapter to use on factory efi man, to adapt holley flange 4bbl. Any ideas?
ONLY if you use the "Price Motorsport Engineering" adapter plates.
EDIT: I just looked them up and their part number is AP-37.
One good thing about them which is not touted is that they turn any intake manifold into an "Air-Gap".
Post  rmcomprandy September 26th 2015, 11:05 am
They also offer a "carb adapter" which mounts on to the F.I. Intake manifold.
Post  wk.ross September 26th 2015, 11:12 am
I see those adapters on their website. Thanks for the info. I am a new member, trying you learn all the in and outs of this groups site!!
wk.ross
Post  wk.ross September 26th 2015, 11:35 am
I found the carb adapters for EFI manifold. Will and old style distributor work in this setup? Like Pertronix?
wk.ross
Post  rmcomprandy September 26th 2015, 3:01 pm
IF you substitute the entire ignition system, there will be no issues.
460 Efi intake swap Empty 460 EFI
Post  wk.ross September 26th 2015, 3:08 pm
I am changing to a Pertronix dist and coil. Just wondered if dist fit correctly before I order
wk.ross
Post  supervel45 September 26th 2015, 6:37 pm
Delete
Last edited by supervel45 on September 26th 2015, 8:07 pm; edited 1 time in total (Reason for editing : Wrong intake)
