Carb and intake swap
I have a Weiand tunnel ram and 2 950 carbs on a 532. I want to swap to a single carb and shorter intake and put a scoop on the car. It is a street car.
Which intake should I use? Can I use one of the 950s I already have or should I buy a dominator?
I am using ported D3 heads.
busta- Posts : 28
Re: Carb and intake swap
i would need to know more info on the engine to tell. if this is in the 500-550hp range and under 6k rpm i would think a 950 would do the job. i run a 600 on my 460 (makes around 375hp) and it runs better then when i had a 750 on it.
bigblockfox83- Posts : 11
» weiand carb adapter 4500 carb flange to 4150 intake
» 750 to 850 carb swap
» intake swap?
» stock efi vs carb and intake
» 460 Efi intake swap
» intake swap?
